Okay, I'm still not able to get this '66 stang 5.0 EFI to start after I installed a brand new fuel pump - which this time is correct for EFI applications.
I have spark at plugs - verified it's a blue spark
I hear the fuel pump prime every time I turn the key to the Run position from Off
Injectors firing as indicated by noid light
I spray starting fluid and the engine fires briefly but does not actually start up. Afterwards the garage kinda smells like ether. I have ensured it was at TDC on the compression stroke with the distributor stabbed and the rotor pointing at the #1 plug wire on the cap. I set the timing at 10° BTDC before trying the ether and it just cranks and cranks.
The only thing I can think of, since it fires briefly when the ether is sprayed, maybe the injectors are gummed up not allowing the fuel to pass through them?
I'm running out of ideas...... all suggestions welcome.
