Still With Oil Leak...What to Check Next?
saxman9801 said:
It should not be much to put the seal in maybe an hour tops at the shop, If I remember correctly the seal was 7.99 , so it should be inexpensive I would hope. Dan
:rlaugh: :lol: :rlaugh: :lol: :lol: :rlaugh:
You have to remove the Fan, remove the belt, remove the crank pulley (since I have the Vortech, I have to remove the blower belt too.), remove the balancer (which can take a while by itself), then the seal (easy part I guess) then put all that stuff back on. I cant see 2 guys working together doing it in under 3 hours.
RC
RC
Forgot you had the blower but still should not be bad at the shop where they have a puller and all that good stuff handy, i did mine when i took out the smog pump It took bout 2 hours to do it all. Dan
i could not bear to read all of this, but i wanted to toss out two cents. (and apologies if im repeating someone else's sentiments).
are you sure you have adequate crankcase ventillation? if not, the pressure finds places to go - often rear main and front crank seals. guys have replaced one or both and had new leaks on new seals due to the lack of crankcase ventillation. i would hate to see that happen to you.
also, once a ventillation issue is fixed, sometimes leaks slow down or stop altogether.
good luck.
