  • SN95 4.6L Mustang Tech
Stock 2v shortblock, pretty impressive
  • Thread starter Thread starter Ibeyorsuperman
  • Start date Start date Mar 26, 2007
  • 3
First Prev 2 of 3 Next Last
02LaserRed2V
379
Augusta, GA
Mar 29, 2007
#21
  • Mar 29, 2007
  • #21
Wow, I've seen ppl with fully built 2Vs with ported heads, cams, on 14 PSI barely make more hp than mine at 9 PSI. KB 1.7L loses a lot of efficiency on anything over 11 PSI. I imagine it'd work better on a stock 281ci as opposed to a stroked motor.
san~man
O-G
A little grass shack on a big lava rock
Mar 29, 2007
#22
  • Mar 29, 2007
  • #22
hotmustang331 said:
pro 5.0 mag had a buildup of a 96 or something GT 2V engine. They pulled out over 600RWHP I believe...I THINK it was RWHP because I recal them putting the engine in a car....but its been a while back.
On the stock internals?
Dusstbuster
I love meat more than anything! I just have a spec
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Mar 29, 2007
#23
  • Mar 29, 2007
  • #23
Yeah I'm wondering on that too...if they made it to that power level it must have been making the power at like 3000RPM and probably blew up right after they finished testing it.
The AF ratio was probably equivalent to a garden hose being fed directly into the cylinders too.
bransdaman78
15
#24
  • Mar 29, 2007
  • #24
that dyno is way off, more and more tuners are pumping up numbers for people... including KB for advertising. get a dyno jet and find out what the deal is
BennyBlown2v
1,233
Carmel, INdiana
Mar 29, 2007
#25
  • Mar 29, 2007
  • #25
What KB does is runs BUTTLOADS of timing and higher octane gas than the tune you receive is good for.
bransdaman78
15
#26
  • Mar 29, 2007
  • #26
YEa i think they sneek a smaller pulley in their to on some of this stuff
and 525 is the most I have seen hold on a stock 2v for more than a month. 600 rwhp is just not believable.
jivepepper
776
Under a Sombrero. in WV.
Mar 30, 2007
#27
  • Mar 30, 2007
  • #27
Good job! Now go flat foot that thing.
the98stang
2,408
Clovis, CA
Mar 30, 2007
#28
  • Mar 30, 2007
  • #28
san~man said:
I have yet to read about an internally stock motor hitting 600 RWHP.
Few people on modular fords have done it. Like I said, it's unlikely to find them, but they are out there. I'm not saying 500whp isn't harsh on the block, but some people out there have done it.
Ibeyorsuperman
123
Ogden, Ut.
Mar 30, 2007
#29
  • Mar 30, 2007
  • #29
My car has already seen over 530hp 650tq at the wheels last year, when i was sprayin...I jus decided to ditch the nitrous and see what i could do with just boost...new fuel pump will be here next week, i'll be takin it to a dynojet on the 14th so we'll see what that says..
Dusstbuster
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Mar 30, 2007
#30
  • Mar 30, 2007
  • #30
It's not even a ticking time bomb anymore at that point...the fuse has already been lit and is in the pre-detonation stage. Wasn't that a beautiful analogy?
Modular_Mike
26
#31
  • Mar 31, 2007
  • #31
What's with all the outrageous claims on the internet???
Post a dyno graph!!!
W
war69
90
Wisconsin
Mar 31, 2007
#32
  • Mar 31, 2007
  • #32
Just wondering if you have any sound clips of your car. I have the same car but and 02 with all the same setup. Just took the car in yesterday to have the stage 2 vt blower cams put in. did you here a noticeable lope and more power. What did it raise your redline to. I cant wait to get it back.
Dusstbuster
May 31, 2004
1,462
33
64
Moorhead, Minnesota
Mar 31, 2007
#33
  • Mar 31, 2007
  • #33
Well if it's stock then the redline wouldn't change, hell with that much power it should probably be lowered.
Duke309
90
Orlando, FL
Mar 31, 2007
#34
  • Mar 31, 2007
  • #34
http://media.putfile.com/98Saleen-Dyno
Stock 98 shortblock (pistons, crank, rings, bearings, etc).
Fox Lake Stage 2 PI heads
Crane cams
PI intake
Accufab upper plenum
BBK long tubes with x pipe
Vortech V2 with aftercooler (3.33 pulley)
KenneBell Boost a Spark
NOS intercooler sprayer
60 pound injectors
255 lph intank pump
T-Rex external inline pump
Stock fuel rails, stock fuel lines, etc.
SCT XCAL2 tuned by Fastlane Motorsports
If i remember correctly it lasted for 3 years before he blew it after adding more power
Ibeyorsuperman
123
Ogden, Ut.
Mar 31, 2007
#35
  • Mar 31, 2007
  • #35
the VT stage II cams are a midrange cam 2500-5500 i beleive, i shift at 5700....but the top end power compliments teh KB low torque nicely.....No sound clips yet, should have some vid when i go back in two weeks..
TweekedGT
1,274
Alberta
Apr 1, 2007
#36
  • Apr 1, 2007
  • #36
Those are impressive numbers indeed. I'm running a 14# pulley on my Stroker motor and not getting those numbers. Due to displacement and flow I'm only filling the block to 10PSI. I'm only putting down a little over 450rwhp on a Mustang dyno. Mind you it depends on your air fuel as well. Mine is a very conservative tune at just 10.3:1 @ WOT. It starts out near 11 at idle but as the RPM increases the A/F drops.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Apr 1, 2007
#37
  • Apr 1, 2007
  • #37
Hmmmmm
A
APiratesLife4Me
#38
  • Apr 2, 2007
  • #38
stock internals
Well that puts my mind at ease. I've been looking at going the KB route and was concerned about my stock internals. I'd love to do cams too, but I'm at 118k on the odometer and really don't want to rebuild anytime soon although It's probably inevitable. My old 5.0 went well past 150k without a hiccup however there was no boost in the equation.
C
cronin49
Banned
Aug 12, 2003
432
SC
Apr 2, 2007
#39
  • Apr 2, 2007
  • #39
007 said:
Exactly what I thought. Not to mention, 500rwhp on stock rods would make me very nervous indeed.
No ****, I'm making 411hp and I'm a little nervous.
DropTopPony
Noob Slayer
2,570
south jersey
Apr 3, 2007
#40
  • Apr 3, 2007
  • #40
TonyG said:
Me neither. Chris Kauffman is making 500+ to the wheels with stock internals. That's the highest # I've seen.
Thats who comes to mind when i think of people running a decent amount of power on stock internals...i think he said he was @550rwhp.
  • 3
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
