  • SN95 V6 Mustang Tech
stock compression question
  • Thread starter Thread starter mustangmat99
  • Start date Start date Apr 28, 2004
mustangmat99
167
  • Apr 28, 2004
i just bought a supercharged car, well i wanna check the cylinder compression, i bougth a lil compression tester from autozone, well i know the factory compression ratio is 9.4:1, but my freind said i need to know the psi of the compression of the factory so i can by that and judge from the meter? so whats my factory psi compression? or am i WAY off base with all this?
Stratus183
179
Attleboro, MA
Apr 28, 2004
  • Apr 28, 2004
According to the Haynes manual the Lowest reading cylinder should be within 15psi of the highest reading cylinder with 100 psi as a minimum pressure.
Hope this helps.
A
atlblue2000
1,245
TN
Apr 28, 2004
  • Apr 28, 2004
Hope this helps.
Nice ride Stratus. I think I may have asked you this before, but where'd you get that hood from? Also, hows that tubular front setup doing for street use?
Question about my weird timing.
  • 2003 mustang gt modded
  • Apr 22, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 26, 2026
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
Misfire
  • Mike3
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2026
Mike3
M
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
