stock ECU limitations
  • Thread starter Thread starter BeaverMeat
  • Start date Start date Nov 29, 2020
BeaverMeat
48
Nanaimo
Nov 29, 2020
  • Nov 29, 2020
Most likely having my engine rebuilt... depends if the block is still good.
While its under the knife I'm wanting to do some upgrades. How far can I go until the ECU needs to be upgraded?
Im wanting to go with a new cam for sure. Possibly heads and intake. As for heads. I still have the stock heads with headers... what heads will still work with the headers? I know there may be a difference in spark plug placement. I don't think Explorer GT40 type heads are the way to go.. interested in going with the GT40X type.
TOOLOW91
20+ Year Stangneter
8,761
234
S.I.NY
Nov 30, 2020
  • Nov 30, 2020
We have got my buddies car to go 8.51-8.55 with a stock ecu and an Anderson pms.
You’ll be fine .
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Dec 1, 2020
  • Dec 1, 2020
The factory ECU with the addition of a Moates Quarterhorse can do some amazing things for over 30 year old technology.
Any head but GT40p should work with your headers. For a mild street build, I would recommend a quality head like the Trick Flow 170s or AFR 165s.
Decipha
221
36
39
New Orleans, LA
Dec 1, 2020
  • Dec 1, 2020
I usually cap the fox ecu's off at around 1,200rwhp. Anymore and things happen too fast. At that point swap to an 03/04 ecu with EDIS ignition and your good to 2,150rwhp no problem.
Reactions: General karthief
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 1, 2020
  • Dec 1, 2020
We did the 58cc GT40X heads with a Tmoss ported Cobra intake on a 306 engine. The engine was 0-decked to get it to 9.7:1 compression ratio. I can find the cam grind for you if you want. The engine runs terrific, and made 302rwhp.
Kurt
BeaverMeat
48
Nanaimo
Dec 4, 2020
  • Dec 4, 2020
Not wanting to go hardcore. Not looking for strip times or anything. Just wanting some more “snap”.
It seems the bottom end is “OK”. The oil pump failed. So... while the engine is pulled I might as well do the bottom end, rings and the cam. Going basic with a B cam as my car is a 5-speed and I prefer mid to high range power... or if I can find somthing similar to the B but cheaper.
I’ll leave the heads, rockers, and intake for later because getting the engine in and out has become the big money burner. Will have to live with a B cam and OE rockers for a bit. Atleast I can do heads while the engine is in the car.
the 5.0 is in a Volvo 240... the mechanic is a bit over the usual 10 hour mark.
Reactions: 90sickfox
90sickfox
Wasn't a pretty sight...and I've got big hands
SN Certified Technician
Mar 2, 2015
6,952
5,831
213
Dec 4, 2020
  • Dec 4, 2020
I'd highly recommend upgrading your valve springs.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Dec 4, 2020
  • Dec 4, 2020
Skip the cam until you can afford to do heads and intake. A cam on an otherwise stock engine is of no value. The 306 we put in the Cobra idles smooth. It's a great street car engine.
Kurt
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
