Stock Fuel Line
sen2two
I've been lubing and pulling it all morning
5 Year Member
Jul 18, 2013
396
58
59
The stock fuel line that crimpes to the hard line down near the passenger side wheel area has and bend/crease in it directly after the crimped portion. Maybe 1/2" away. It may even be slightly cracked and leaking. I don't see how just this short section can be replaced by itselt because it is crimped. I only got 2 minutes to look at it and then it rained....
So, until I can get back out there and really look at it. Is this a replaceable section?
So I just went a took a look real quick, yes its still raining. Lol...
Not worth replacing that one section. I'm looking for a complete fuel line upgrade from there to the rails. Possibly the rails as well. Looks like the feed hard line would be a -4 and return a -6.
Can someone confirm this? It's raining harder now so I can't really get a good measurement at the moment.
Those lines are not the issue. It's the lines that those connect to that lead to the hard lines.
Are you referring to the nylon fuel lines that connect from the rails to the hardlines on the passenger's side frame rail?
If so, you can buy replacement pieces from the automotive store or places like jegs. Use a heat gun or hot water to soften the end of the line before sliding it over the barbs. It takes a little practice, but like most things, Google search it or YouTube it.
Joe
I've decided to upgrade. I know the rails are good until a lot more power than I'll be making. But I noticed that somewhere in the cars life, the rubber hoses had been replaced. With rubber hose NOT meant for fuel. It says it right on the damn hose.
That's why I'm looking at the kit I posted above.
