Strange electrical problem... losing power while driving.
nisreo
178
Ok, so I have a 90 GT. Stock besides an exhaust. There are also no 02 sensors in the car if that matters.
When I'm driving say at the top of 1st, if I shift quick and get on the gas, the car starts bucking like crazy and I can see my dash lights and gauges losing power and flickering.
I put the clutch in and let the rpms slow down and let the car stop bucking, then I can get back on the gas. Also I can get on it as long as I slowly shift and ease into the next gear. I haven't noticed any symptoms of this problems when going over bumps, so I dont think its a loose connection anywhere.
any info is very appreciated
Thanks
-Brian
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See http://www.troublecodes.net/Ford/
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
attachment.php
89 through 95 cars have a working Check Engine light. Watch it instead of a test lamp.
attachment.php
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see http://www.midwayautosupply.com/pc-7208-90-equus-digital-ford-code-reader-3145.aspx – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Never disconnect the battery from an alternator. The electrical spike produced before the alternator output drops to zero can damage things like the computer, radio and even the alternator itself.
Auto Electrics 101: Generators will run without a battery. The iron core for the field coils will retain enough magnetism to create the magnetic field required to make electricity.
Alternators like the ones used on Mustangs require a battery to power the rotating field windings. That's because the AC current they generate internally demagnetizes the iron core for the field coils when there is no battery current to power them. The diodes inside the alternator turn the AC current into DC current. There are 3 phases to the alternator’s internal circuitry & 6 diodes to rectify the AC current into DC current. The battery acts like a big sink or capacitor to smooth out the remaining pulses
There are some self exciting alternators, but I have never seen one on a Ford or GM car. The last self exciting alternator I worked on was a 200 amp 110 volt one in a Convar 580 twin turboprop airplane. That was over 30 years ago…
