  • SN95 4.6L Mustang Tech
Strange gurgling noise...
  • Thread starter Thread starter BetterBaGT
  • Start date Start date Sep 15, 2010
BetterBaGT
49
Phoenix, AZ (unfortunately)
Sep 15, 2010
  • Sep 15, 2010
The last week or two I've noticed what sounds like my exhaust gurgling (like with mouth wash). It happens only when my tac. is between 2000 and 1000 rpms and on the way down (decelerating). Also sometimes happens at idle. It is worse in the morning before the engine warms up but sometimes still happens when it is warm.
At first I was positive it was coming from the exhaust, now I'm not so sure. ANY HELP WOULD BE GREAT! I have no idea what the problem is.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Sep 15, 2010
  • Sep 15, 2010
Are you looking for a guess?
Clogged cats or exhaust. Perhaps a baffle has rusted out in the muffler. Water trapped in the muffler.
Get under the car and hit the exhaust with a rubber mallet. Listen for anything that is rattling.
Any changes recently? Did you remove the square chamber between the IAC and the intake tube?
BetterBaGT
49
Sep 15, 2010
  • Sep 15, 2010
Clogged cats or exhaust. Perhaps a baffle has rusted out in the muffler. Get under the car and hit the exhaust with a rubber mallet. Listen for anything that is rattling
Yes, I will take any guesses at this point. And no, I have made no changes in the last 3 months.
I will try what you suggested, but I'd love some other input.
trinity_gt
3,125
81
99
Canada
Sep 15, 2010
  • Sep 15, 2010
Boy, diagnosing sounds over the internet is virtually impossible, especially without a clip.
"Gurgling" from the exhaust on the overrun could be normal until the PCM enters or exits decel-fuel cutoff. A little unburnt fuel burning in the exhaust can make gurling noises; the exhaust becomes much quieter when the PCM shuts off the injectors after a sustained period of decel. Or it could be the DFCO you're hearing that goes away when the PCM re-starts the injectors as the engine nears idle-speed while decelerating.
Not enough info. See if you can get a clip.
BetterBaGT
49
Sep 16, 2010
  • Sep 16, 2010
I'll see what I can do. Owe, and it's been idling a bit high as well. Not sure if that helps.
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
