Strange Headlight Problem !
  • Thread starter Thread starter Mikie
  • Start date Start date Dec 7, 2006
Mikie
the ahead of you horseman
Aug 2, 2000
517
Belmont NC
Dec 7, 2006
  • Dec 7, 2006
Guys,
I just purchased a set of the sylvania silverstar Ultra bulbs to replace my factory ones that were very dim. I popped the old ones out and put in the SS bulbs. Simple project that took all of 10 minutes. After this I went to cut on the headlights and noticed that in either dim or high position the blue hi beam indicator stays on the whole time the headlights are on. It doesent really matter as they work fine and I know the difference between high and low without some dash light telling me, but wanted to know if anyone else has experienced this?
I know for a fact they are hooked up right as the pins only are allowed to enter one way with the plugs.
Any thoughts?
Thanks
Adams91LX
689
12
29
Plano, TX
Dec 7, 2006
  • Dec 7, 2006
did you try putting the other bulbs back in just to see if the problem still occurs?
Mikie
Aug 2, 2000
517
Belmont NC
Dec 7, 2006
  • Dec 7, 2006
I did...
and still the same thing.
HISSIN50
34
129
Dec 7, 2006
  • Dec 7, 2006
The high beam indicator gets power directly from the MF switch as I recall. If you jiggle the MF switch stalk, does the light go out?
Mikie
Aug 2, 2000
517
Belmont NC
Dec 8, 2006
  • Dec 8, 2006
Its very early here and I just read your reply. Sorry for the complete ignorance bro, but what is the MF switch and stalk ?
Thanks
tbovee
129
Fredericksburg Va
Dec 8, 2006
  • Dec 8, 2006
That would be the Multi function switch and turn signals, hi / lowbeams lever or handle.
Mikie
Aug 2, 2000
517
Belmont NC
Dec 8, 2006
  • Dec 8, 2006
I will check later today on that.
Thanks to all.
Mikie
Aug 2, 2000
517
Belmont NC
Dec 8, 2006
  • Dec 8, 2006
I checked on the stalk and there seems to be something very interesting happening. Nothing that will indicate a short or loose MF switch, but the positioning is wrong.
What I mean is...
When your sitting in the seat and have the stalk in your left hand you can either push it forward or pull it back to flash the brights. Mine now has lost its mind, the position of the stalk pushed away from you is supposed to be the high setting. Mine is the low setting now WTF???
So now the bright setting is in the middle and when you pull it to you it does not flash the bright lights becasue they are already on !
Holy ****, Where is that bottle of tylenol
HISSIN50
34
129
Dec 8, 2006
  • Dec 8, 2006
I'm not one to toss parts at something, but it sure sounds like your MF switch took a dump.
Mikie
Aug 2, 2000
517
Belmont NC
Dec 8, 2006
#10
  • Dec 8, 2006
  • #10
Im going to continue to investigate it, but I think you might be right.
Thanks and I will yell if I find out.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
K
2003 Mustang GT Convertible Headlight H/L Issue
  • krysber
  • Mar 20, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 21, 2025
85GTStangGuy
M
Headlights
  • Magnet86
  • May 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
Blown88GT
