Strange Noise coming from rear?
89GT331
18
Fitzgerald, GA
Kinda a odd noise. I just put adj. control arms on the car and braced the torque boxes. Took the car out for a test run and now I hear something that sounds like the rear end is moving? You only hear it when you are getting down on it at first or if the damn thing bucks. I am gonna recheck all the control arm bolts tomorrow night when I get home, but I know I torqued them all down. Its a sharp sound, almost sounds like its coming from the driveshaft. Anyone have any thoughts? I checked the driveshaft to see if I could see any marring but no dice, so I dont think that its hitting. Think the pinion angle could be out?
  • Sponsors(?)
89GT331
18
Fitzgerald, GA
OKay brain fart detected....Had to adjust the lca on the passenger side to try and square the rear back, but I believe I adjusted a bit too much and the damn drive shaft is bottoming out in the tranny. So back to the lift and this time getting some professional help.
Thread starter Similar threads Forum Replies Date
zhendo95 Strange Knocking Noise Coming From Front End. Help!!! SN95 4.6L Mustang Tech 0
onefstsnake Strange Noise Coming from Engine/Drivetrain Fox 5.0 Mustang Tech 6
The Green GT Strange noise coming from the back wheel. 1994 - 1995 Specific Tech 12
screamin gt Strange brake noise, hot front brakes 1996 - 2004 SN95 Mustang -General/Talk- 5
R Right rear clunk when hitting bumps 2015+ Specific Tech 6
Z Strange Noise 1996 - 2004 SN95 Mustang -General/Talk- 2
S Strange Noise Under the Hood Help Needed! 07 Mustang GT 2005 - 2014 S-197 Mustang -General/Talk- 3
F Brakes Strange Brake/suspension Noise 1994 - 1995 Specific Tech 4
D Strange Vibrating Noise 1996 - 2004 SN95 Mustang -General/Talk- 3
fox-gt Strange Noise Since 3g Alternator Upgrade Fox 5.0 Mustang Tech 8
02shtangGT Engine Strange Humming/growling Noise Behind Dash?? 02 Mustang Gt SN95 4.6L Mustang Tech 2
B Strange Noise From Air Intake 1996 - 2004 SN95 Mustang -General/Talk- 4
Racegt Bad Idle And Strange Rattling Noise At High Rpm's The Welcome Wagon 2
96GTYUSUF Strange Squeaking Noise 1996 - 2004 SN95 Mustang -General/Talk- 15
B Strange Noise While Accelerating In Higher Gears? 1996 - 2004 SN95 Mustang -General/Talk- 3
K Strange Noise, Bad Tob??? SN95 4.6L Mustang Tech 3
03_TrueBlue_GT Some Idle Issues And Strange Noise SN95 4.6L Mustang Tech 8
MikeUrban Strange engine noise? Fox 5.0 Mustang Tech 17
Black95GT_Kid strange strut noise? 1994 - 1995 Specific Tech 3
ttwolff06 Strange Noise Please Help. 2005 - 2014 S-197 Mustang -General/Talk- 5
03_TrueBlue_GT Car Is Making Strange Noise 1996 - 2004 SN95 Mustang -General/Talk- 13
J Strange Noise In Exhaust At Higher Rpm's 2005 - 2009 Specific Tech 2
03_TrueBlue_GT Car makes strange noise from rearend SN95 4.6L Mustang Tech 7
G 02 GT making strange noise after I added refrigerant SN95 4.6L Mustang Tech 4
B Strange gurgling noise... SN95 4.6L Mustang Tech 4
K Strange Noise SVT Tech Forum 9
A Got a strange noise in the engine. SN95 4.6L Mustang Tech 0
jayrw Strange noise when AC is on - But goes away when depressing clutch SN95 4.6L Mustang Tech 3
9 strange noise 1994 - 1995 Specific Tech 4
geoffsgt strange transmission noises SN95 4.6L Mustang Tech 7
disturbdgt strange noise SN95 4.6L Mustang Tech 5
fawcett Strange Noise Comming From Rear End 1994 - 1995 Specific Tech 3
I Strange Winding Noise and Vibrations Fox 5.0 Mustang Tech 2
SadbutTrue Engine starts (woot), starter making strange noise/having trouble turning it over Classic Mustang Specific Tech 12
M strange noise SN95 4.6L Mustang Tech 1
doobsstang Strange Noise 1994 - 1995 Specific Tech 7
T strange noises 2.3L (N/A & Turbo) Tech 3
aaros strange ticking noise Fox 5.0 Mustang Tech 5
Black_02_GT strange popping noise... SN95 4.6L Mustang Tech 5
I Strange Noise @ 50 mph SN95 4.6L Mustang Tech 5
B Strange Noise, Suggestions SN95 4.6L Mustang Tech 12
97woodward Getting a strange Clunking noise SN95 4.6L Mustang Tech 17
callmedrlove Strange speaker noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
BCB00GT Strange noise when braking SN95 4.6L Mustang Tech 7
T Strange engine noise Fox 5.0 Mustang Tech 15
darkhorse1 strange noise SVT Tech Forum 2
hotdog71 Strange Gear box noises? SN95 4.6L Mustang Tech 0
Stanger007 HELP - car making strange noise - alternator bearing??? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
G strange noise SN95 4.6L Mustang Tech 1
R 1991 Mustang Strange noise???? Fox 5.0 Mustang Tech 6
