  • SN95 4.6L Mustang Tech
Strange smoking problem
  • Thread starter Thread starter oxfordgt
  • Start date Start date Mar 11, 2008
oxfordgt
288
Clarksville, TN
Mar 11, 2008
  • Mar 11, 2008
I just installed the trickflow track heat intake and moroso aluminum valve covers. The valve covers came with no holes for a PCV system so I had them drilled. There is no baffeling in the valve covers.
The only time it smokes is a small puff at start up and a lot after making a right turn. After a left turn or driving straight there is no smoke.
I have a catch can on the passenger side between the PCV valve and the intake.
Any ideas.
Also the shortblock is forged and only has 5000 mile on it. The heads were reconditioned 5000 miles ago and had new seal, springs and locks installed.
D
darkside03gt
851
Sacramento CA
Mar 11, 2008
  • Mar 11, 2008
is the smoke deffinetly coming from the exaust?
oxfordgt
288
Clarksville, TN
Mar 11, 2008
  • Mar 11, 2008
Yes the inside of the tips are black
oxfordgt
288
Clarksville, TN
Mar 13, 2008
  • Mar 13, 2008
I figured it out. The new moroso valve covers have no baffeling and was sucking oil right out through the pcv. I just deleted the PCV and its running fine now.
M
Marlboro_Man
437
Houston, TX
Mar 13, 2008
  • Mar 13, 2008
Deleting the PCV isn't necesarily the best idea though. See if you can fab some baffles to work in the valvecovers.
Possibly...Header evac time.
Smokeurhonda
457
Maryland
Mar 13, 2008
  • Mar 13, 2008
PCV is there for a reason. You will really start to contaminate your oil if you don't pull those vapors out of the crankcase.
jstreet0204
939
Winston Salem, NC
Mar 13, 2008
  • Mar 13, 2008
Deleting the PCV replaces it with filter vents, or at least it should. The downside is you have to put up with some smell. I've had mine vented for years.
Smokeurhonda
457
Maryland
Mar 13, 2008
  • Mar 13, 2008
True, as long as something is venting. But he said his new valve covers had no provisions for PCV. Not sure if he vented or not.
jstreet0204
939
Winston Salem, NC
Mar 13, 2008
  • Mar 13, 2008
He said he had hole drilled for them.
Smokeurhonda
457
Maryland
Mar 13, 2008
#10
  • Mar 13, 2008
  • #10
True, but ya never know what some people do with their cars .
oxfordgt
288
Clarksville, TN
Mar 13, 2008
#11
  • Mar 13, 2008
  • #11
Yes I vented both sides. I have hose going to catchcans then to filters on both sides. It is venting fine and I have no smell inside the car.
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
