strangest engine problem ever!!!
Your going to have oil underneath the seals at the shims and locaters or spring cups, that is 100% normal.
Did you have the guides checked by a competent machine shop that told you they are worn?
I have a 350 motor that has oil that drips out of where the headers meet the exhaust and i have massive blow by from the pcv valve and oil comming up through the valve covers, it ran good just smoked alot i thought bad rings or scored cylinder walls i did a compression check and they all checked out good the plugs are covered in oil but still fire, i pulled all of the pistons and the rings are good im lost does anyone have any idea? and the intake gasket was good no leaks this is a new 350 with only 800 miles on it
