I was going to take the intake plate off of my stock intake and got 3 of the screws out fine, but the one i didn't get out now has a stripped head. I was wondering if there was a way to get the screw out?
You could try one of those screw extractors (stripped torx heads arent unlike phillips heads) or cut a slit into the head and use an impact driver with a straight (screwdriver) head to remove the fastener. Hit the fastener with PB for a bit before trying to remove it.
I was considering using one of the screw extractors, but didn't know how well they worked. I already have screws to replace it. Since the screw is set down in the plague it makes it hard to slot it or cut the head off
