STROKER QUESTION
  • Thread starter Thread starter GATOR98GT
  • Start date Start date Mar 19, 2004
G
GATOR98GT
185
BRISTOL
Mar 19, 2004
  • Mar 19, 2004
I was thinking about stroking my engine from a 302 to a 347. This is the popular one no? My question is what is the cost involved in this and also how hard? could a couple of weekend mechanics like me and my friend do the job in the backyard with some patience and the right tools? How much power would I be looking to gain with the change? Any info would be helpful. Thanks
stangbear427
2,401
New England
Mar 19, 2004
  • Mar 19, 2004
Yes, it's the popular one, because it's the biggest stroke advisable on a 302 block. Some folks milk a 348 out of them, but it isn't a great idea. You can get into a stroker kit for well under $2000, but it will probably require some machine work to the block which isn't really a weekend mechanic thing. Other than that, you should be able to pull it off yourself. With the parts list in your sig, you should have a good 350HP or so without the spray- but don't quote me on it.
331 cobra
398
Silicon Valley CA
Mar 19, 2004
  • Mar 19, 2004
You can't do it in a backyard unless you buy a new shortblock or long block and just install your intake and/or heads on the new block, pull the old motor, then stick the new one in.
I have heard some conflicting things about 347 power. If you use all stock parts, you may not gain much power, but you will add a lot of low end torque. If you have a proper set of heads, cam and intake, you will gain a lot.
I would budget a minimum of $2500 for this project. You might be able to do it cheaper, but that will either be from using cheap parts, doing some of the work yourself, or luck.
It's about 8-900 for the really cheap 347 kits on ebay, then you have to either put your car out of service for weeks, or buy a donor motor. $500+ for a bore and hone, deck the block, ballence job and hanging the pistons. Then there are the little things, timing chains, bolts, gaskets, oil pan and pump, they all add up.
If you don't want to take any chances with how those things add up, just get a shortblock from ford. They are pretty cheap and it's a no brainer.
When I look at those prices and what you get, I would rather spend 4-5k and get everything forged in a race block. It can be done with top shelf parts if you bargain hunt and take your time. I just got some $1,000 Lunati rods for $500 through Ebay. I'm now looking for pistons and a crank.
I'm waiting for World products to start making their WindsorR race block. It's suposed to be out by the end of april for about $1500. That's a good deal when a sportsman is rated for only 600hp at $800+ and the Dart's are over $2,000.
That will leave me with $3000 for my crank, pistons and oil system. I think I'll be able to scrounge that for less, but I don't expect to have my engine done before 2005.
bmo37
2,368
New Jersey
Mar 19, 2004
  • Mar 19, 2004
i had mine built for $2000 included, new 302 block, cast crank, forged i beam rods, probe forged dished pistons, balanced and blueprinted and assembled, .030 overbore, and new main support.
331 cobra
398
Silicon Valley CA
Mar 21, 2004
  • Mar 21, 2004
I just bought a Trick flow forged crank from summit for $511 shipped.
http://store.summitracing.com/showclearance.asp?d=1&s=8&c=1
It's on clearance and I must say that it has to be better than buying a chinese eagle crank for about the same price.
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Motor given to me and I’d like to rebuild it what do I need to do
  • Creomod
  • Dec 14, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2024
AeroCoupe
