yes pulling under braking can also be cause of caliper sticking,jack it up and have someone hit the brake then release while you turn each wheel see if one has some hard friction,if you find one sticking make sure it isnt a collapsed line by cracking the bleeder while someone holds the pedal,if it squirts its not a bad line if it trickles well you know the drill.
