  • 1994 - 1995 Specific Tech
Stud Mount vs. Ped. Mount
  • Thread starter Thread starter DFG 5OH
  • Start date Start date Dec 4, 2005
1 of 2 Next Last
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
  • Dec 4, 2005
Whats the pros/cons of using stud mount rockers and ped. mount rockers? I need a set for my heads, and want to know which would be better?
Matt
SuperDust22
The Power of Pixie Dust?!
Oct 19, 2003
1,821
Gilbert,AZ
Dec 4, 2005
  • Dec 4, 2005
Ped mount rockers are the same as the stock style, I believe that the stud are just stronger. Other than that I don't not know the pros and cons between them.
Dustin
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
  • Dec 4, 2005
thanks dustin, i'll probably just run ped. style to make it easy
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 4, 2005
  • Dec 4, 2005
Studs are a bit stronger and more stable.
Another thing I like about them is ... ease and flexability when adjusting valve train.
Down side to em is they are more costly with guide plates and hpr's.
but worth it IMHO!
Grady
Blackened302
1,439
South TX
Dec 4, 2005
  • Dec 4, 2005
screw-in studs are what i hear it's at. something about strength and durability.
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
  • Dec 4, 2005
i might look into studs on my P heads...thanks grady
CManT1914
3,172
Killeen, Texas
Dec 4, 2005
  • Dec 4, 2005
Studs are stronger and easier to adjust the lash on. Ever tried adjusting lash on pedestal mounts? You gotta use shims, huge PITA. The only downside is the neccessity of guideplates, which then require hardened pushrods. But they are SO worth it if you are installing them yourself.
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
  • Dec 4, 2005
ok...where can i get a stud mount 1.7 RR KIT from?
CManT1914
3,172
Killeen, Texas
Dec 4, 2005
  • Dec 4, 2005
eBay, classifieds, summit, anywhere really.
I got my 1.6/1.7's from eBay.
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
#10
  • Dec 4, 2005
  • #10
hey, i found some comp cams 3/8th stud 1.7's...but it says that you dont need guideplates...is this right?
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Dec 4, 2005
#11
  • Dec 4, 2005
  • #11
what heads are you using these on? if your using em on the p's your gonna have to get them machined
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
#12
  • Dec 4, 2005
  • #12
yea i would be using them on the P's...why would i need them machined
urban96
3,464
Syracuse, NY
Dec 4, 2005
#13
  • Dec 4, 2005
  • #13
p heads are setup for ped mount. a machine shop would have to machine down the pedastals and i think re-tap them to run stud mount
bimmertech
1,123
merriam, ks
Dec 4, 2005
#14
  • Dec 4, 2005
  • #14
it's a real pita to machine the heads right. they have to take off some material on the mount pads, drill out the holes, and tap larger holes for the studs. taking of the material is to accomdate the increased install height of the guid plates and studs. if you don't plan on spinning your motor over 6k, save your money. just my .02
urban beat me too it, but do you really want to sink all that money into some P-heads. use your stock rockers, and save up for some nice alum heads with studs already in them.
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
#15
  • Dec 4, 2005
  • #15
well ****...i was planning on spinning the motor past 6k...
bimmertech
1,123
merriam, ks
Dec 4, 2005
#16
  • Dec 4, 2005
  • #16
i'm just sayin it'll prolly cost you about $600 after parts and labor to convert your heads to stud mount. sell those P's and use that 600 to buy some used stud mount alum heads and rockers.
but yeah, if you are spinning over 6k stud mount is pretty much a requirement.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 4, 2005
#17
  • Dec 4, 2005
  • #17
Everybody try to remember this as it will help later on when you think about this subject.
All Ford 5.0 OEM Iron Heads are set up for ped rr's.
Its a cheap way to turn em out and thats why Ford did it.
I have seen in the past, some kits to convert to stud mount but the whole deal was kinda Mickey Mouse as the stud was so tiny ... IIRC 5/16. Anyway, just not strong enough for a serious effort.
For iron heads, I still say this if you are gonna only be using them for a while
Don't buy new rr's for them cause they are gonna be peds and I can't see the sense in moving those rr's to a nice flowing Aluminum head when you go to the next level. Just use the stock rockers and don't take the hit in the wallet when you sell the iron heads. As for the gain from rr's ...... give me a break ..... 5 hp or less ...... Just don't make sense to me!
It would take a good bit of $$$ to do studs correctly on Ford OEM heads.
I'll never change my mind about sinking money into iron heads
Grady
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
#18
  • Dec 4, 2005
  • #18
i see...well thanks for the info...i guess i'll keep lookin for ped. mount
DFG 5OH
1,341
Louisville, KY
Dec 4, 2005
#19
  • Dec 4, 2005
  • #19
grady, i will be keeping the iron heads for a long time...although i'm not going to put the money into them for stud mounts, i'll just get some 1.7's and be done with it. Thanks for the info
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Dec 4, 2005
#20
  • Dec 4, 2005
  • #20
HA ...... HA ...... HA
I said that once upon a time about a set of self poted E7's I now got just laying around in the garage
"and be done with it"
That was exactaly what I said when I was porting the E7's
Lets tell the truth about what we ALL want from our combos ...........
just a little more
Grady
1 of 2 Next Last
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
Best Ebay aftermarket Radio/screen
  • Shurkeel
  • Oct 8, 2026
2005 - 2014 S-197 Mustang -General/Talk- Oct 9, 2026
gkomo
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
Motor mounts question
  • djj62478
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 13, 2026
nickyb
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
