  • SN95 4.6L Mustang Tech
Studder problem?
  • Thread starter Thread starter 87_turbostang
  • Start date Start date Jan 30, 2008
87_turbostang
  • Jan 30, 2008
My brother has a 97 mustang gt and he is getting a studder in it when he exccelerates. He changed plugs and wires and he said he gapped the plugs. Both coil packs have been replaced and i cleaned the mas air flow sensor. Any other suggestions would be great!
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jan 30, 2008
  • Jan 30, 2008
Check the vacuum lines and all hoses. Also make sure the PCV valve is good and has no oil blow by.
04YELLOWGT
1,135
Indiana
Jan 30, 2008
  • Jan 30, 2008
Has he checked the plugs to make sure they havent started backing out? This can happen if they weren't tightened down enough.
O
ottos
  • Jan 31, 2008
The motor is misfiring. Sounds like your hardware is a-ok tho. Try regapping plugs to something tighter, like 0.040" or 0.035". If not, try new PCM calibration from Ford dealer, but that runs $80. Fixed my 99 GT that was doing the same ****.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jan 31, 2008
  • Jan 31, 2008
Is he sure it's a missfire issue and not a problem within the drivetrain. A bad U-Joint will make the car shudder when taking off as well.
98E9GT
110
  • Feb 1, 2008
My car was doing something similiar, i dunno how well this is, but i unplugged my maf sensor and it seemed to run a little better, so i just got another maf sensor and my problem was solved.
M
MichaelsLilGray
32
Tyler, Texas
Feb 1, 2008
  • Feb 1, 2008
to be honest.. if you remove the MAF.... and it smooths out.. :Your throttle response should go to hell... cause your computer doesnt know what is going on. So it reverts back to the dump fuel command and blindly shoots fuel into the engine... If if didnt do anything.. which is kinda bad.. it is your MAF
87_turbostang
  • Feb 4, 2008
thanks for all the help. but i think i found the problem. we changed the alt the other day and i pulled the spark plug wires from the plug and found that coolant had got down in there and upon futher inspection i seen that the thermostate housing is leaking on the bottom.
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
