  • SN95 4.6L Mustang Tech
stupid girly question but...
  • Thread starter Thread starter Seraphitia102
  • Start date Start date Oct 6, 2006
1 of 2 Next Last
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Oct 6, 2006
  • Oct 6, 2006
what is PI and non-PI? I hear these terms and have no clue what they are. Is my car PI or non-PI?
Dope 97GT
439
Rochester, NY (SUNY Brockport)
Oct 6, 2006
  • Oct 6, 2006
PI and non PI refer to the cylinder heads on the 96-04 mustang gts or the 4.6 sohc engines. From 96-98 they had the NPI heads which made around 40 or so hp less than the 99-04 cars which had the power improvement cylinder heads.
Your car is a PI car because of the year 99-04.
four six
506
Hobart, IN
Oct 6, 2006
  • Oct 6, 2006
PI heads are the Power Improved heads that came on 1999-2004 GTs
Non-PI heads are non-power improved heads that came on 1996-1998 GTs.
The heads have a lot better flow over non-pi. Yes you car has PI heads
four six
506
Hobart, IN
Oct 6, 2006
  • Oct 6, 2006
damn you beat me by a split second
BooWFO
991
Louisville, KY
Oct 6, 2006
  • Oct 6, 2006
You all forgot the fact that the PI cars have slightly better, intakes and cams. Combined the heads, intake, cams make them PI.
Dope 97GT
439
Oct 6, 2006
  • Oct 6, 2006
yeah nice addition
sgarlic
3,085
Oct 6, 2006
  • Oct 6, 2006
PI is power improved. Oops, did it already get answered 10 times? My bad.
merc123
420
North GA
Oct 6, 2006
  • Oct 6, 2006
SOHC = Single Overhead Cam
DOHC = Dual Overhead cam
Figured I'd cover the bases.
BlackenedSVT
1,841
New Jersey
Oct 6, 2006
  • Oct 6, 2006
I'm actually surprised you dont know that. You've been around these forums for a while now. Just surprised you haven't asked any of us earlier
But now ya know
Twista
510
@ the z00 in chicago
Oct 6, 2006
#10
  • Oct 6, 2006
  • #10
BRB= Be back right
LOL= Laugh out laugh
ROFL= Rolling on floor laughing
BBL- Be Back Later
TTYL= Talk to ya later
BBIAB= be back in a bit
GDawg
1,469
Nevada
Oct 6, 2006
#11
  • Oct 6, 2006
  • #11
Not only are the heads different between PI and NPI but so is the lower intake manifold. Some people have put a PI manifold on NPI heads and have seen slight gains.
Shiroelex
There's nothing worse than aut
728
Westland, MI
Oct 6, 2006
#12
  • Oct 6, 2006
  • #12
PIITB = :SNSign:
merc123
420
North GA
Oct 6, 2006
#13
  • Oct 6, 2006
  • #13
Shiroelex said:
PIITB = :SNSign:
Beat me to it.
GDawg
1,469
Nevada
Oct 6, 2006
#14
  • Oct 6, 2006
  • #14
Shiroelex said:
PIITB = :SNSign:
I'm glad you guys cleared that up for her...
Let's stay respectable and not the old TangNet that had no class...
Seraphitia102
Oct 11, 2004
737
California
Oct 6, 2006
#15
  • Oct 6, 2006
  • #15
sweet i learned something today, thanks guys
Twista
510
Oct 6, 2006
#16
  • Oct 6, 2006
  • #16
DIAF= Die in a fire.
M
MBDiagMan
171
Lamar County, Texas
Oct 7, 2006
#17
  • Oct 7, 2006
  • #17
One of your questions has still not been answered. An S281 is a supercharged engine, so whether or not the base engine is PI or not you are WAaay up on power compared to a normally aspirated (non super charged) engine of either type.
As explained, this involve different and MATCHING cams, heads and intake manifold.
The Cams are entirely different in that the earlier cams are designed with a longer duration (leave the valves open longer), shorter lift philosophy while the PI cams use a shorter duration, higher lift philosophy.
The cam design philosophy change is to take full advantage of the high flow characteristics and flow pattern of the PI heads. For this reason if one were to change heads on an early engine to PI, they will be missing some of the power addition available if they do not also use PI intake and cams.
Dope 97GT
439
Oct 7, 2006
#18
  • Oct 7, 2006
  • #18
not all saleens are supercharged i believe the speedsters are and the s281extremes are hers is not.
jstreet0204
939
Winston Salem, NC
Oct 7, 2006
#19
  • Oct 7, 2006
  • #19
s281's are not supercharged. s281sc's and s281E's and a few others got a superharger. s281 is the base model.
GDawg
1,469
Nevada
Oct 7, 2006
#20
  • Oct 7, 2006
  • #20
She doesn't have an actual Saleen hence the "Faleen" in her sig. She has a regular PI engine.
1 of 2 Next Last
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Valve hitting piston?
  • krazedstang
  • Jun 9, 2025
SN95 4.6L Mustang Tech Jun 12, 2025
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
