Stupid question
RsStanG1987 said:
Did they make a notch back capri? I seen someone driving a notch with a capri front...
No, but what you saw is easy to do.......
Cliff :)
Tackleberry said:
Love that four eyed front end...How hard was it to do? It is pretty unique and is very sharp. :nice:
All of the Capris & Stangs have the same lines at the front of the fenders, so you can pretty much swap any of the noses. Some may require different fender extensions. In my case, I left the GT ground effects in place and just cut out the headlight area so I did not have to worry about the fender extensions, or body side moldings. I did not even remove the whole bumper cover. I cut it in two while bolted in place, then removed the upper half only. Did the same basic thing with the Capri nose. All of the noses mount with six studs on each side going through the fenders, all noses have the studs located the same. Then there is also two supports in the center that bolt up to the upper radiator support. The header panel had to be modified in my application. That’s the fiberglass panel, which the headlights mount to, inside the bumper cover.
It’s fairly easy to do, and I’ll be doing another soon.
Cliff :)
Edit: I almost forgot, I did have to change the wiring some. The plugs are all different, but the color coding for the wires is the same for all foxes. Also, my car does not have side marker lights which is illegal I believe.
~FrankenStang~ said:
Yep, my car is actually a 1980 Capri... Well, just the body. Everything removable was removed and replaced with 1990 Ford Mustang parts.
You better watch who you let know about your aero Capri.
You'll have a legion of a s s w i p e s talking all kinds of stupid chit.
Got any better pics?
Here is my 80 Capri, unfinished at the moment, no hurry. :D
I've been thinking about bolting the body together and dropping one of my spare engines into it just so I can drive it a little.
Cliff :)
