  • 2005 - 2009 Specific Tech
Sub Frame Connectors on 08 Vert?
  • Thread starter Thread starter GusinCA
  • Start date Start date Dec 8, 2007
G
GusinCA
170
Newport Beach
Dec 8, 2007
  • Dec 8, 2007
Do you guys recommend getting aftermarket welded subframe connectors on a new 08 GT vert?
I have an 00 GT vert and it made a huge difference, but I'm wondering if the 08 needs it?
If so, recommendations?
A
ARTTII
272
Detroit, MI
Dec 8, 2007
  • Dec 8, 2007
Do they even make SFCs for the s197 chassis? It is not at all like the pre-05 chassis... Not sure what they would connect on this car
G
GusinCA
170
Newport Beach
Dec 8, 2007
  • Dec 8, 2007
That's what I was wondering.
Or is the vert already so stiff that it doesn't need it?
M
MikeysOTP
203
  • Dec 8, 2007
It can't be all that stiff since the Super Snake will have 725hp and the vert will ONLY have 600hp since they don't feel the chassis is stiff enough for the added power.
G
GusinCA
170
Newport Beach
Dec 8, 2007
  • Dec 8, 2007
Ok, well, how about for the normal GT?
burke07gtcs
64
Farmington NM
Dec 11, 2007
  • Dec 11, 2007
BMR Fabrication has a nice set. I put them on my GT & love them makes it real easy to jack up the car & it is more rigid too.
spyder7724
28
  • Dec 11, 2007
I read an article a year or so ago and it claimed that the new generation mustang in stock trim is equally as stiff as a fox body(sedan) with a full cage and welded frame connectors.
Maybe on a vert if you have loads of torque it's a good idea but probably not as necessary on the GT as previous models.
I like the idea of an easier jacking point though.
A
anticubicle
268
  • Dec 24, 2007
Correct me if I'm wrong but aren't the S-197's full chassis cars? I'm pretty sure that's the case and if so, there is no real need for Subframe connectors.
P
plnfixr320
55
High Desert CA
Dec 24, 2007
  • Dec 24, 2007
The S197 is still a uni-body car. No full frame.
anthony05gt
1,262
Maryland
Dec 24, 2007
#10
  • Dec 24, 2007
  • #10
Unibody, and it's 30% stiffer than the previous generation. You won't need sub frame connectors unless running big hp...like 600 plus.
G
GusinCA
170
Newport Beach
Dec 24, 2007
#11
  • Dec 24, 2007
  • #11
Yep, all the places I've contacted don't make them for the vert.
It is pretty stiff on it's own, but a convertible can always use more stiffening.
Y
Speed density 302 to carb 351W
  • yaboity
  • May 29, 2026
  • Fox Engine Swaparoo
Fox Engine Swaparoo May 29, 2026
AeroCoupe
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
M
Aftermarket Brake light help needed
  • Mustang Steve
  • Mar 17, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 17, 2026
Mustang Steve
M
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
