  • Special Production
Roush Subframe Connecter Question
  • Thread starter Thread starter sal07b
  • Start date Start date Mar 27, 2007
First Prev 2 of 2
marcus95
2,133
California
Apr 1, 2007
#21
  • Apr 1, 2007
  • #21
Sal,
Just make sure the shop that installs them has installed subs before. They need to know to grind the powdercoat off in the appropriate places. Most importantly is that they don't insall them backwards. I have seen muffler shop guys do that many times with subs. Good luck and you will be happy.
sal07b
477
Springboro Ohio
Apr 1, 2007
#22
  • Apr 1, 2007
  • #22
marcus95 said:
Sal,
Thanks Marcus. I'm not sure if the shop has installed them or not. Stupid question, is there any identifying marks for front/back of the SF connectors? In other words, how will I know which way is correct vs. which way would be considered backwards? I highly doubt these guys would have put these specific ones in on a mustang before. Not all of us have dozens of Mustang tuners w/in 20 miles of one anonther as you guys in CA do...
2000xp8
SN Certified Technician
Aug 8, 2003
8,058
1,643
194
NJ
Apr 1, 2007
#23
  • Apr 1, 2007
  • #23
Sal, any chance you can find a chassis shop around you?
IMO, i'd trust them a hell of alot more than muffler guys.
sal07b
477
Springboro Ohio
Apr 2, 2007
#24
  • Apr 2, 2007
  • #24
I'll look around and see. I have a line on a guy that runs a shop here in town that comes highly recommended. Of course, that doesn't mean he's ever put a set of these on (or even seen a set for that matter...lol)...
bill89saleen304
176
Everett Wa.
Apr 2, 2007
#25
  • Apr 2, 2007
  • #25
Make sure whoever you have do it, knows what they are doing!!!!
The car has to be sitting on it's own weight, on all four wheels, when it is welded up, or you most likley won't be able to open or close your doors.
I had a friend of a friend weld his on, on a hoist with the wheels hanging down, and couldn't open or close his doors, and had to cut them off, and redo them when he found out the correct way to install them!
Just thought you should know this, if you didn't already, to save yourself a big headache!! Also consider boxing in your tourqe boxes at the same time, it's pretty simple to do, I did mine when I put them on my car!
See Ya Bill
SVT Saleen
456
#26
  • Apr 4, 2007
  • #26
See Ya Bill
The same thing almost happened to me & my '89. I originally purchased a rectangular set of connectors from a company who shall remain nameless (they are still in existence BTW). When the installation shop placed them up on the car there were huge gaps between them & the floorpan. We called the company & they said that the weight of the car had to be resting on the connectors to properly install them. Naturally the installer & I knew that this was the completely wrong way to install connectors so I sent them back & instead purchased the MAC tubular connectors.
sal07b
477
Springboro Ohio
Apr 5, 2007
#27
  • Apr 5, 2007
  • #27
Thanks for the info! I wouldn't have figured the car would have to be on its own weight prior to installation. This is why I like this site. All kinds of good information...
marcus95
2,133
California
Apr 5, 2007
#28
  • Apr 5, 2007
  • #28
Sal,
JUst so you know the absolute proper way to install full length subs to have the car itself in the air and completely leveled with the wheels hanging. Like Bill said if the car is not leveled then the doors may not open. rookie installer mistake.
The only reason why the professionals install the subs with the chassis leveled and the suspension hanging is that not every car sits level on it's own wheels. you know spring sag in one corner and so on.
sal07b
477
Springboro Ohio
Apr 6, 2007
#29
  • Apr 6, 2007
  • #29
marcus95 said:
Sal,
GREAT! I'm giong to have to figure out where a chasis shop is! I can see trying to explain this to a person who hasn't done the install before. So let see if I've got it:
- Have to grind off the powder coating prior to welding
- Car has to be level
- May be under own weight (not necessarily level)
- May have wheels hanging (still has to be level)
- Have to ensure that the welder takes his time so not to heat up to much (carpet fire)
Oh yea, and definately have to hold your mouth right with tounge slightly to the left...
TT91
1,536
Paramus, NJ
Apr 7, 2007
#30
  • Apr 7, 2007
  • #30
Get a wire wheel on some sort of grinder, dont GRIND the powder coating off.
Fill a spray bottle with water and dampen the carpet while hes welding.
deezbluballz
43
Nebraska
Apr 7, 2007
#31
  • Apr 7, 2007
  • #31
I had my local Midas weld them on for cheap. I have HPM subframe connectors. Made a ton of difference.
sal07b
477
Springboro Ohio
Apr 14, 2007
#32
  • Apr 14, 2007
  • #32
Well, I got the Global West connectors and seat braces in on Thursday, and had them installed yesterday. The only hiccup was on the passenger side. I had my car shipped back from Arizona and the guy apparently torqued the crap out of the come-a-long's. He placed the hooks into the holes on the subframe and cranked the car down for shipping. Unfortunately, he bent the crap out of the passenger side rear, which made it a pain in the a$$ to weld-up the sub frame connector on that side. The guy that did the welding had to do a little filing, but it turned out pretty good. He even pained the welds afterwords to prevent rust (like the car will ever be in the elements to allow it to rust...NOT). Doors open/close fine. Unfortunately, it was raining today when I picked the car up, so I drove it straight home and put it in the garage. I'll post how I think it "feels" once it actually decides to be friggin Spring back here on Ohio...
Side Note: Pretty smart how they put the Global West decals in just the right spot so people can see them if the car is lifted...
Tommy98016
89
New York
Apr 16, 2007
#33
  • Apr 16, 2007
  • #33
good to hear you did not have a problem like this guy
more pics can be seen by clicking here
First Prev 2 of 2
Subframe connector question
  • B0udreaux
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 5, 2026
rednotch
L
Door pull panels, convertible versus coupe
  • lenzgt
  • Jun 25, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 25, 2026
lenzgt
L
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
9
New from northern MN
  • 91firecracker
  • Apr 19, 2026
  • The Welcome Wagon
The Welcome Wagon Apr 19, 2026
