subframe install troubles...
  • Thread starter Thread starter Jarrett
  • Start date Start date Sep 18, 2010
Jarrett
12
Seattle
Sep 18, 2010
  • Sep 18, 2010
so i bought MM full length subframe connectors and i noticed my front subframes are pretty beat up. on the passenger side the seat bracket and rear subframe are flush but the entire front subframe is about an 1/2 inch off. Driver side the front of the subframe is about a 1/4 inch off and the rear of the frame is like 3/4" inch off, looks like someone jacked it up on the rear of the driver side subframe and left it there, i do notice a bow in the floor pan compared to the passenger side. i always jacked it up on the pinch weld.
how can i fix this?
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Sep 18, 2010
  • Sep 18, 2010
frame machine
Jarrett
12
Seattle
Sep 18, 2010
  • Sep 18, 2010
you think beating them down from the inside with a sledge hammer will work?
skunk21
1,203
Taxachusetts
Sep 18, 2010
  • Sep 18, 2010
I would take Shaolin Crane advice or atleast take it to a good body shop and have it looked at. might need some light pulling etc. you cannot push down or beat down the short " frame" sections via the inside of the car since they are hollow sections welded to the floor pan. you can just about make out the path of the rail by looking in the trunk or hatch area but again no access ( I could see this when looking at friend rotted out trunk and rails). the only thing you can really push down from the inside would be the floor itself if it got pushed up but even then certian areas would make that hard. The body shop can weld tabs onto the frame section and pull them out and square it up. important to note that it's not a good idea to weld on SFCs on a floor section or car that isn't straight because it's going to be worse when done and harder to fix, just like a thread I read years ago with pics of a guy who welded some on jack stands with the car crooked and the doors would hardly shut after for starters. This is just some advise since I'm not getting a visual of what you are dealing with but if it where my car and those section where that badly crushed or messed up I would bring it somewhere.
1990_GT
41
Marysville Wa.
Sep 19, 2010
  • Sep 19, 2010
If you have a stud nailer and a slid hammer you might be able to get most of the dents out that are on the subframe, but if the frame is tweaked take it to a frame shop.
7-UP BILL
885
My other car is a Firetruck
Sep 19, 2010
  • Sep 19, 2010
Welcome to the world of twisted frame Foxes. Chassis rack is the antidote.
Suspension Is somethig Wrong Here?
  • Icemanxxxv
  • Jul 11, 2026
Fox 5.0 Mustang Tech Jul 11, 2026
AeroCoupe
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
Brakes How do I get the e brake cable onto the disc brake caliper??
  • AnthonyA1234
  • May 2, 2025
Fox 5.0 Mustang Tech May 2, 2025
AnthonyA1234
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
