Suggestions
  • Thread starter Thread starter Brando8912
  • Start date Start date Jun 29, 2010
Brando8912
38
  • Jun 29, 2010
I am new to modding but learning as I go. I am looking for some suggestions on where to go next. I have a 95 GT 5 speed. Next weekend Im installing a Mongoose clutch, trickflow street burner upper and lower, bbk 70mm throttle body, new comp cams double roller timing chain, bassani cat-less x pipe and prochamber mufflers with 2 1/2in pipe.
Next on my list is some 3.73 (because i will do some highway driving) and some subframe connectors.
Now when it comes to the next step im not sure where to go. When you make a suggestion let me know why.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Jun 29, 2010
  • Jun 29, 2010
I always invest in a good shifter on a 5 speed car. It's not that expensive, and it makes a huge difference.
Kurt
9
94gt5.o
177
ferndale WA
Jun 29, 2010
  • Jun 29, 2010
Suspension would be a good thing. With those gears i would most def get upper and lower control arms. It makes such a diffrence, as for suspension i have kyb struts and shocks and am very pleased. As for the next engine mod sounds like a set of heads.
Brando8912
38
  • Jun 30, 2010
I am not that knowledgeable when it comes to heads. Can you give me some direction on what I am looking for. I am not gonna get a supercharger or turbo on this car. I want it to be all motor. Not going crazy either. Can I stick with the stock heads and go with some roller rockers and new valve springs or should i get a different set of heads and work off those?
9
94gt5.o
177
ferndale WA
Jun 30, 2010
  • Jun 30, 2010
First off our stock heads SUCK that is one of the main problems with our cars. with your build id go with sum gt40s heads and have them redone by a local shop. They are still a iron head and you can find them fairly cheap and its a good increase in power and should work well with your set up. There is tons of info on these heads and there are lots of smart guys on this fourm to help you
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 30, 2010
  • Jun 30, 2010
With an open ended Q such as that you are gonna get all kinds of
replies cause what makes a great Stang to one is not the same
to another Stang owner
At least give a major category
Do you wanna have ..............
more power
go around corners better
look better
etc
Grady
Black95GTS
1,644
Marlborough, MA
Jun 30, 2010
  • Jun 30, 2010
Short throw shift as Kurt mentioned, also under drive pulleys are great for a gain across the entire RPM range, same with long tube headers.
Adam
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jun 30, 2010
  • Jun 30, 2010
If u get gt40s....don't get them reworked. By the time u spend that money you might as well buy used aluminum heads like trickflow twisted wedge or edelbrock performer.
9
94gt5.o
177
ferndale WA
Jul 1, 2010
  • Jul 1, 2010
this is true but i ment if he could find a good shop with a good price that he should go that route but u do have a great point
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Jul 1, 2010
#10
  • Jul 1, 2010
  • #10
Yea my biggest suggestion is to put any plan onto paper...with $ estimates. Then add an extra piggy bank for the stuff u forget about.
Often times some ideas seem great...but once u get down that path you're better off doing something else
I bought an entire explorer motor with gt40p's and about 70k on it for $500. Swapped the springs, converted to stud mount rollers and ran them. That may be a better option for now depending on where the OP wants to be in a few years.
I wish i could go back to the old me and tell him to just save and buy what i want...1 time. Instead of buying this here....that there.....this here....then realizing im buying crap twice. Yea....it takes longer. But in the end, it saves $$$$$$$$$$$.
Brando8912
38
#11
  • Jul 1, 2010
  • #11
I was looking at a set of gt40 heads to put on it and also swap out the cam. With all of this will the stock MAF handle all of this or will I need to start upgrading with that, fuel pump and injectors? Also any recomendations on a cam? There is sooo much to choose from.
Black95GTS
1,644
Marlborough, MA
Jul 1, 2010
#12
  • Jul 1, 2010
  • #12
How much you wanna spend? You won't be able to make enough power N/A with GT40 heads to require an MAF upgrade.
Adam
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Oil choice for after break in period.
  • Sask84gt
  • Feb 28, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 14, 2026
Praetorious
P
D
97 V6 suspension upgrades
  • Dale1bre
  • Jan 18, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 19, 2026
