Sunroof Latch Removal Problem
  • Thread starter Thread starter BKM48198
  • Start date Start date Jul 2, 2017
BKM48198
377
27
49
Ypsilanti, Michigan
Jul 2, 2017
  • Jul 2, 2017
Finally redoing my interior, seat upholstery, headliner,sun visors, and carpet.........I started taking everything apart and have it all apart except for the latch for the sunroof, it should be just 2 nuts that need o come off but the bolts are spinning, they have round heads and there is no way to get to the head to grab it with vice grips ............any ideas on how to get the things loose so I can install the headliner without drilling holes thru the sunroof channel to get to the bolt heads? PS I tried to use superglue to hold the bolts and no luck.
Mustang5L5
Mod Dude
Feb 18, 2001
43,374
18,121
224
Massachusetts
Jul 2, 2017
  • Jul 2, 2017
Got a pic? Because my sunroof has actual nuts.
(This pic not mine)
Reactions: Chad91gt and Shakerhood
BKM48198
377
27
49
Ypsilanti, Michigan
Jul 2, 2017
  • Jul 2, 2017
Those are the nuts,but they are connected to bolts that spin. The headliner goes between the latch and the roof so I need to get those two nuts off but unfortunately the bolts they are on are not welded in or removable and there is no way I have seen to get anything on the bolt head to stop it from turning. The only thing I can think of is to drill holes above the bolt heads and try to grab it or just cut the nuts off and then replace the bolts and then seal the holes with black RTV silicone to keep water out.
BKM48198
377
27
49
Ypsilanti, Michigan
Jul 3, 2017
  • Jul 3, 2017
Here is a pic of how the mount looks without the headliner in the way.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Jul 4, 2017
  • Jul 4, 2017
Hard to tell from your Pic but I almost think I recall seeing a different pic of your car and thinking it has an aftermarket sunroof.
General karthief
Mod Dude
Aug 25, 2016
28,133
10,749
213
polk county florida
Jul 4, 2017
  • Jul 4, 2017
You could try an air inpact, it may spin it off or wedge a screw driver between the bolt head and the metal above it but I'm not a fan of that one unless it's a brace and not the roof skin.
1969, 1970 mustang heater box repair/replace instructions (no AC)
  • 70mstang
  • Apr 9, 2023
6K
Classic Mustang Specific Tech Apr 9, 2023
70mstang
Drivetrain Suggestions for removing a bolt with a "rounded/stripped" head?
  • markinms
  • Sep 27, 2020
2K
Fox 5.0 Mustang Tech Oct 5, 2020
Adieu
R
Long Broken Bolt Story
  • Rcdgl
  • May 27, 2018
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 30, 2018
Rcdgl
R
Old H/c/i Installation Explanation And Pics
  • FastDriver
  • Jan 26, 2018
2K
Fox 5.0 Mustang Tech Jan 27, 2018
FastDriver
Timing Cover/harmonic Balancer Removal And Replacement
  • jrichker
  • May 28, 2017
16K
Fox 5.0 Mustang Tech Jul 6, 2024
