Supercharged 351W
I'm looking into supercharging my carbed 351W combo in my 90' GT.
Does anybody know if this has been done? I would have thought somebody has tried it somewhere but have had no luck finding anything.
I was thinking about a Paxton, using my stock accessories. I've emailed them, but haven't got a reply.:shrug:
u would need about the same as a blow thur carb turbo set up. u need a carb hat,reg that increases fuel pressure under boost,a carb for a blow thur, blow off valve. u would have to make the pipe from the sc to the carb
I'd assume it would be very similar to a blow through turbo set up, most likely you can use a lot of the same piping for the supercharger to carb portion. Carb hat will obviously be needed but I'm sure it can be done
