  • SN95 4.6L Mustang Tech
supercharged engine???rotating assembly or shortblock
  • Thread starter Thread starter spdfrkaby
  • Start date Start date Jul 17, 2005
spdfrkaby
82
Minot, North Dakota
Jul 17, 2005
  • Jul 17, 2005
Hey everyone, don't know too much about the lower end. I have a ProCharger P1SC and was wondering if I would be able to just change out the lower end with a forged crankshaft, upgraded pistons and upgraded h-beam rods. Would that be enough to make 500-550 hp or would I need to upgrade the whole shortblock. There's package deals for the rotating assemblies around $1400. Much cheaper than a short block. I'm noob in this area so please take it easy on my. Thanks.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 17, 2005
  • Jul 17, 2005
forged crank with forged rods and pistons should be fine. the block itself is strong.
RedBullitt
462
Morgantown WV
Jul 17, 2005
  • Jul 17, 2005
yeah, the stock block will take plenty of abuse, its just your glassy internals you ll have to worry about. forge the internals and you should be fine
Ghostface
226
Jul 17, 2005
  • Jul 17, 2005
you have to consider the cost of labor unless you can do it yourself.
O
obselite
  • Jul 17, 2005
you'll be fine with what you're looking at. Make sure the internals you're getting are all forged (as stated above).
Just as an FYI, I was going to be running 800 FWHP and my block was going to be just fine (according to VT).
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jul 17, 2005
  • Jul 17, 2005
what you're not factoring in is labor. you do not want to assemble a shortblock by yourself unless you are very experienced in it. have a reputable shop do it. it sounds like the kit you are talking about for $1400 does not include bearings and piston rings. plus, you'll need to have the block honed .020" over on the bore to make the pistons fit and balance the whole thing.
a professionally built shortblock is going to cost around $3200 and be able to withstand much more than 550hp.
J
jimfitzgerald
6,672
  • Jul 17, 2005
What he said. A professionally built shortblock will be worth the difference in price. You may also want to consider an aluminum block for weight reduction. That's what I did with my last build. Modular Powerhouse can assemble a nice shortblock for you.
Mike97gt
it doe snot
10,633
Jul 17, 2005
  • Jul 17, 2005
thats true.. i was thinking more on the lines of what is needed i did not factor in any skill of whoever is doing the work or labor cost..
the best way too go for a whole new motor is to get a VT shortblock or one from another reputable engine shop.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jul 17, 2005
  • Jul 17, 2005
ya doing build your self can be fun. i know i had alot of fun when i built my old 4A-GE engine for my old MR2. But without good knowlege, and experience, you might just want to get already built by proffisional short block. it'll save you many bucks down the road, and don't ask me now i know
spdfrkaby
82
Minot, North Dakota
Jul 17, 2005
#10
  • Jul 17, 2005
  • #10
Thanks for the input guys. I wasn't planning on doing the install myself, my luck I'd make it worse. I'm headed back home from Germany to Atlanta in a few months and I'm going to get everything done at ModularPowerhouse, i.e. charger, gears, axles, fuel pump, subframes and clutch and was maybe thinking about doing the rotating assembly while I'm there. I found some prices below that were pretty good. I hear nothing but good things from the companies. I know to stay away from CHP, not to many good feedbacks on them. Anyone have any idea on how much this would be to get installed?
$1710 balanced
http://www.livernoismotorsports.com/product.phtml?p=1000
$1850 balancedhttp://www.livernoismotorsports.com/product.phtml?p=1001
$1495
http://www.seanhylandmotorsport.com...=1170&osCsid=cf7771302953932d7db0c6b91ee42b73
$1995
http://www.seanhylandmotorsport.com...=1171&osCsid=cf7771302953932d7db0c6b91ee42b73
J
jimfitzgerald
6,672
#11
  • Jul 17, 2005
  • #11
$1710 balanced
$1495
$1995
In that case, definitely let Modular Powerhouse build you a shortblock. Do not buy a rotating assembly and take it to them for the install. MPH has suppliers and connections and can get everything you need and it will be better than any rotating assembly you can purchase from SHM or anywhere else.
spdfrkaby
82
Minot, North Dakota
Jul 17, 2005
#12
  • Jul 17, 2005
  • #12
Guess I'll have to wait a little longer then for the lower end to be built up. I'll stick around the 400 hp range until I can't take it anymore and cave in with money or no money.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
Progress Thread 351w stroker rotating assembly and build
  • Ric4eyedFox
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 24, 2025
Help with Engine Build
  • 93gtmustang
  • Nov 13, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 17, 2024
AeroCoupe
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
