  • SN95 4.6L Mustang Tech
supercharged PCV setup?
  • Thread starter Thread starter the98stang
  • Start date Start date Jan 20, 2007
the98stang
2,408
Clovis, CA
Jan 20, 2007
  • Jan 20, 2007
I want to know what all you 4.6 guys are usnig for PCV setups. I heard the Supra PCV's are good, but I don't know if they will fit my 00' GT. Does any one have a part number for the PCV/grommet?
Also, how can I set up an oil seperator? Should I use a valve cover breather? Any info is appreciated!
Tanner
hotmustang331
2,967
Bastrop,TX
Jan 21, 2007
  • Jan 21, 2007
I think alot of people have a one way valve installed....but thats a bad idea IMHO. You want the crank case venting, ESPECIALLY @ WOT/high RPM...and that one way valve only allows for that under part throttle.
A. Put little breather on your valve covers
B.route the PCV lines into the powerpipe/inlet side of the blower, with an oil/water seperator inline before it gets the the blower.
C. Do the same as above but vent the line straight down towards the underside of your car.
A. will probably put a thin oil layer over everything after a while
B. Could put a thin coating of oil on your MAF (unless its after the MAF...but im not sure if thats a good idea)
C. Could over a long time put a thin coating of oil on the underside of your car.
Me? I went with C, and with no oil spereator...its a bit dirty under the car, but not bad at all.
Im not sure how bad it will be after the FI is complete though.
But theres no way im going to risk coating the MAF...that = LEAN as I have a blow through setup....I even went as far as not using any oil based air filters....I run HKS style foam filters.
They are the EXACT SAME as these...just cheaper off EBAY and say "mazdaspeed" on the center button instead of HKS.
http://www.nipponpower.com/product.phtml?p=79&i=1
Stan Weiss
347
Philadelphia, PA
Jan 21, 2007
  • Jan 21, 2007
Like into a vacuum pump system that will produce a Crank Case Vacuum & eliminates Pressure buildup and at the same time add a few HP as well. This is race technology that has come to street vehicles.
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 21, 2007
  • Jan 21, 2007
Unless you are concerend with emissions, just get rid of your PCV setup altogether. Aside from emissions the PCV valve is worthless, especially on a blown motor where those one way check valve will hardly ever open. You can either run a filter on the valve cover like hotmustang331 suggested, or you can also run some sort of crankcase vacuum like Stan suggested.
With a blower, you are going to have some pressure in the crankcase. So I would recommend running a filter/separator on the valve cover and just put a vacuum cap wherever your PCV hose connected to the intake system.
Something like this:
Places like Moroso/Competition Engineering, Allstar Performance, K&N, etc will make these products. I know SHM carries one specifically made for the DOHC valve covers, but I don't know if they have one for the 2 valve yet. Might call and ask.
hotmustang331
2,967
Bastrop,TX
Jan 21, 2007
  • Jan 21, 2007
^Will unplugging and removing that little PCV valve on the pass side valve cover cause any porblems? I seen it there, but all it does is freegin leaak oil it seems....so I was wondering if you knew exactly what it did .
Note: reason I ask is because it has a sensor plugged into it....didnt know if it would cause an engine light to come on.
BennyBlown2v
1,233
Carmel, INdiana
Jan 21, 2007
  • Jan 21, 2007
It's not a sensor, its a heater. 04's have heated PCV's.
hotmustang331
2,967
Bastrop,TX
Jan 21, 2007
  • Jan 21, 2007
Thanks! I thought it was some sort of a valve or something with a sensor. But I do have to wonder what the point of a heated PCV is
LaserRed01GT
Banned
Oct 3, 2006
739
Clearwater, FL
Jan 21, 2007
  • Jan 21, 2007
Yes, the later model Ford's got heated PCV valves. The primary purpose of this was for cars that would be driven in cold weather climates. It's not uncommon for moisture to accumulate within the crankcase and if it is below freezing outside and the motor is just being started, there is a possibility of the throttle blade icing. The heated PCV valves are supposed to help eliminate throttle blade icing.
I cannot find any specific heated PCV valve codes in any of my manuals, so I think by just unplugging the heater, you will just be turning the heater off. Shouldn't set any codes.
hotmustang331
2,967
Bastrop,TX
Jan 21, 2007
  • Jan 21, 2007
Thanks Laser I guess I should leave it alone then haha. Its not hurting anything I guess, and it was all iced over here a few days ago...may need it in the winters haha.
the98stang
2,408
Clovis, CA
Jan 22, 2007
#10
  • Jan 22, 2007
  • #10
Well I'd like to keep the PCV system because CA is really gay when it comes to smog.
Keep in mind I will be running 8-10 pounds of boost, so the pressure won't be that much. Do you guys think a better flowing PCV would be sufficient such as the Supra PCV? What if I capped off the boost pipe bung and put a breather on the driver side valve cover?
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jan 22, 2007
#11
  • Jan 22, 2007
  • #11
Check out JLT's PCV filters. They should be all you need really.
the98stang
2,408
Clovis, CA
Feb 8, 2007
#12
  • Feb 8, 2007
  • #12
I'd like to keep the PCV system so I can pass smog. I just need to know what PCV will be best for my set up. I'm thinking either the supra or TB PCV. But I'm not sure which one will fit/work better. Any ideas?
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
J
Engine Coolant leak from oil filter
  • jr273
  • Mar 26, 2026
SN95 4.6L Mustang Tech Mar 31, 2026
squeak93
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
M
Resolved PCV Tube and Valve Cover Breather Hole Locations
  • MDrisc
  • Sep 11, 2024
Fox 5.0 Mustang Tech Sep 22, 2024
MDrisc
M
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
