supercharger alternator problem
  • Thread starter Thread starter Mike in Texas
  • Start date Start date Sep 9, 2008
M
Mike in Texas
121
  • Sep 9, 2008
Well, I'm into the installation of a NOVI 1220 on my 90 LX. Everything went pretty smooth until I tried to connect the alternator wiring. First it wouldn't reach, I solved that, but now one connector does not have clearance because the sway bar ( I guess that's what it is) is in the way. I'm going to see if clocking the alternator will solve the problem but would like to know if anyone else has experienced this. My concern is that somehow I've screwed up the alternator mounting although I don't see how that is possible. Any S/C guys with alernator connector clearance problems?? Thanks for any help.
jd-hart
124
Greensboro, NC
Sep 9, 2008
  • Sep 9, 2008
Lengthing the wires is sometimes needed. I have a 3g alternator and the power wire connector is a tight fit, but nothing major. Are you sure the swaybar is in the correct position? Maybe some very badly worn bushings?
I have a Vortech, but I believe the brackets are pretty much the same.
Good luck!
G
2000 GT- Alternator not charging
  • grugug
  • Tuesday at 8:30 PM
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Thursday at 9:04 AM
squeak93
F
Electrical From scratch: alternator wiring
  • fox racer v2
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 23, 2025
fox racer v2
F
Electrical 1985 mustang gt Led conversion trouble
  • 1985fox
  • Jan 5, 2026
Fox 5.0 Mustang Tech Jan 15, 2026
1985fox
J
Emission problems
  • jls.zmmr
  • Feb 5, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Feb 7, 2026
AeroCoupe
1976 Cobra II fuse problem - Solved (I hope)
  • Rick Tanner
  • Jan 8, 2025
1974 - 1978 Mustang II Talk & Tech Jan 8, 2025
