supercharger issue
  • Thread starter Thread starter raistlin77
  • Start date Start date Apr 3, 2011
R
raistlin77
28
  • Apr 3, 2011
Installed a new v3 vortech 6psi. Had issues with idling at first. I was able to fix it with moving the valve cover breather to the inlet tube. I still have a problem with bogging/missing. I am using the the fmu with all new OEM ignition components, and Lowered the gap on the plugs. i notice it more when i let off the throttle and then reapply throttle. I have researched the forum but i am out of ideas. Not sure if it is fuel,ignition,vacuum or possessed. The car did run fine before the install. I would like to get it tuned but i believe this problem would still be there with a tune. Plus money is short right now. Any help would be appreciated.
Only other mods are cobra intake and full exhaust. I do have a AFR and it shows lean during this problem.
R
raistlin77
28
  • Apr 5, 2011
anybody
BYRDPE
1,556
Memphis,Tn.
Apr 5, 2011
  • Apr 5, 2011
so you have a wb 02 and it shows lean during re-accelleration? do you have a boost gauge and if so, is it showing boost during this instance? are you running stock injectors...if so with what fmu dics?
R
raistlin77
28
  • Apr 6, 2011
I do have a boost gauge and fuel pressure gauge. the car is not in boost during this moment. Fuel pressure does increase also. This problem occurs during normal driving. I have attempted today to isolate the egr and I unplugged fuel evap from the upper intake, did not work. I also did a code check which showed 94,44,34,12. I have removed the diverter valves and plugged the vacuum lines. Isolating the egr caused code 34. Number 12 does interest me, I need to research this more. Any advice would be appreciated.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
  • brandyn200
  • Jun 20, 2026
AeroCoupe
