Supercharging Questions.
  • Thread starter Thread starter Shakin66
  • Start date Start date Apr 25, 2006
Shakin66
628
Waycross, Ga / Lake James, NC
Apr 25, 2006
  • Apr 25, 2006
I am trying to get my car running for my sons birthday on May 7th since I promised him a ride in it but have ran into some issues. Being that I am blowing through the carb. is there anyway to modify the secondaries since they are currently vacuum operated? I have taken the vac. pod off of it sealed the orifice and am using a bolt throught the butterfly linkage to accuate throttle shaft Also I have a vac. advanced distributor and worry that it may not operate correctly when under boost. Stupid questions I know but I am new to supercharging. Also FYI I did modify the carb to be ready for boost but hope this vac. secondarys issue isnt a stopping point.
classic boost
709
canton, oh
Apr 25, 2006
  • Apr 25, 2006
www.turbomustangs.com they have a carb forum.
regarding the vac adv, as long as it's hooked up to a timed port (not pulling vacuum at idle), then it'll be fine.
iskwezm
4,159
20
79
Rowland Heights,California
Apr 25, 2006
  • Apr 25, 2006
i did the same carb mod when i had my 750 vac sec. it worked but get a real carb made for it.I was told by EVERYBODY that vac. sec. wouldnt work.
MickeyK65Stang
105
Laguna Hills, Ca.
Apr 26, 2006
  • Apr 26, 2006
I went through the same thing, never could get the seconary's to open. Finally went to a manual sec. carb. solved all my problems.
BlueMonster65
385
Connecticut
Apr 26, 2006
  • Apr 26, 2006
mech sec would be better but
there is a thread located on www.turbomustangs.com in the carb forum that addresses converting a vac. sec. carb. for blow thru. it is however easier and safer to modify a mech sec carb for blowthru.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
J
Hello all, I have returned from a hiatus... Update and Questions
  • JackH
  • Aug 13, 2025
1974 - 1978 Mustang II Talk & Tech Aug 15, 2025
JackH
J
R
  • riored97snake
  • Jun 18, 2026
  • What is it Worth?!?!?
riored97snake
R
E
Alternative IACs?
  • Ethereal_Zer0
  • May 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 7, 2025
CAMTWO1070
2001 roush stage 3 - sat for 5 years
  • Brando_05
  • Aug 26, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 26, 2025
Brando_05
