superchraging a stock engine.
  • Thread starter Thread starter accidentprone86
  • Start date Start date May 29, 2005
accidentprone86
189
Westminster Colorado
May 29, 2005
  • May 29, 2005
So i have decided that the best route to take will be to superchrage my engine stock so then when i decide i want to build it up i can get heads cam and intake for a forced induction motor insted of fiting a super charger an a engine built for n/a power.
I am going to get a vortex v2-s trim "the quite one"
What do i need to think about and do to make good power and keep daily drivable reliability?
How much power can i expect to make?
thanks
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
May 29, 2005
  • May 29, 2005
as contractors say...... Build a strong foundation before you build the house.
translation: that blower set up is gonna cost ya a pretty penny. Now, if i was you, i would get a Comp Cams XE grind cam, TF TW heads and an RPM intake. this way you have natural power before you go into the SC aspect.
but if you go the blower route, you could expect to gain anywhere from 70-100hp depending on the tune and matching components like a throttle body, etc etc.
edit: you might not wanna go wtih the cam due to your 86 heads, but get something good to flow the air that the supercharger is pushing.
accidentprone86
189
May 29, 2005
  • May 29, 2005
my point for doing a blower first is that i would be able to then buy heads a cam and an intake that is opimized for a supercharger. instede of going the n/a route then puting a supercharger on it. i cant get a s/c and h/c/i all at once. it would be a long time in between geting the two so i would not want to be driving n/a on a set up for a blower because i did not have the money to get the s/c with the h/c/i.
N8Miller
2,661
Kingston, PA, USA
May 29, 2005
  • May 29, 2005
are you going to get a blower motor made? by that i mean low compression or just use your stock 9.0:1? If your going to keep that compression ratio, you could add heads, cam and intake now rather than doing a blower and it will be fine for NA AND when you get a blower put on.
did you plan on a custom cam or an OTS cam?
Rick 91GT
Mustang Master
95
99
PA
May 29, 2005
  • May 29, 2005
I like the idea of the blower on the stock motor personally. If I had to do it all over again on a street car it would be exhaust, then a blower.
I would suggest a conversion to MAF, and a 24-30# inj, 190lph fuel pump. Keep the stock cam until you change some other components, the gains will be minimal... you can go 10's on a stock cam believe it or not with that blower.
When your ready to build the motor I would go with a stronger piston and bottom end, the 86 block is one of the stronger stock blocks out there.
Just be prepared to build a stronger foundation when you add heads, cam and intake..you'll need it.
Venom351R
4,548
41
98
MAINE
May 29, 2005
  • May 29, 2005
WHY ???
Im running a S/C on a stock motor. pulling almost 400 at the wheels untuned and have no issues at all.
Venom351R
4,548
41
98
MAINE
May 29, 2005
  • May 29, 2005
Not everyone wants 500+ RWHP.
P
PRO50SC
1,012
Olney, Maryland
May 29, 2005
  • May 29, 2005
My suggestion, if I had to do it all over again. Buy a crate motor and make more hp than the blower set-up. Time you get done with buying a good blower set up, all the things that will have to go with it(injectiors, mass air, a good tune and whatever misc things that pop up. You could spend the same or less money for a good healthy crate motor. Looking back, that is what I would have done and had a fresh motor to boot!
P
PRO50SC
1,012
Olney, Maryland
May 29, 2005
  • May 29, 2005
Striped5.0 said:
WHY ???
Your pulling almost 400 ponies and running a 13.7@ 103. Something doesn't sound right.
cjman15
Banned
Apr 15, 2004
1,009
Fairfield, PA
May 29, 2005
#10
  • May 29, 2005
  • #10
Yeah def... can you drive? haha jk
accidentprone86
189
May 29, 2005
#11
  • May 29, 2005
  • #11
well **** dont know what to do. their is some many things i want to be able to run 12s at my altitude 5800. so really more like 11s where most of you guys are.
I want to be able to drive it daily as well and not have to work on it constantly.
N8Miller
2,661
Kingston, PA, USA
May 29, 2005
#12
  • May 29, 2005
  • #12
yeah, i noticed that too. you should be running high 11s at like 117mph or so.
accidentprone: i was just saying that you could do heads, cam and intake and make the power that is going to be near equivalent to the blower. Only thing is that once you add the blower and get "bored" with it, then you have to tear it all down anyway to add the stuff.
Rick makes a very good point though too. I would love to get a "rough" '90LX and put an exhaust and a blower on it for the wife to drive as a toy. They say tha there is nothing really like feeling the blower spool up and "kick" in.
Scorcher2005
883
South Carolina
May 29, 2005
#13
  • May 29, 2005
  • #13
Striped5.0 said:
WHY ???
if you have 370rwhp and 425tq, y are you only going 13.7s?
Scorcher2005
883
South Carolina
May 29, 2005
#14
  • May 29, 2005
  • #14
damn, just realized that you beat me to it :-/
RED92VERT
74
#15
  • May 29, 2005
  • #15
If you keep the boost at 6lbs you should be fine. My buddy has 450rwhp on his stock 95 hypercrapnic shortblock. The only problem he has had was a blown headgasket.
N8Miller
2,661
Kingston, PA, USA
May 29, 2005
#16
  • May 29, 2005
  • #16
he doesnt have hyper. pistons, he has forged.
88 Fox GT
1,674
Iowa
May 30, 2005
#17
  • May 30, 2005
  • #17
They switched from forged to hyper. pistons in '94. So, he should have forged.
slowhatch82
583
NJ Pine Barrens
May 30, 2005
#18
  • May 30, 2005
  • #18
88 Fox GT
1,674
Iowa
May 30, 2005
#19
  • May 30, 2005
  • #19
slowhatch82 said:
93
Really? Well, then I learned something today.
V8SHME8
120
Gainesville, Fl
May 30, 2005
#20
  • May 30, 2005
  • #20
The problem is that he has an 86 so he has not valve reliefs. If you change heads, then you have to notch the pistons. You might as well, just change pistons if you are gonna be in there. I would get an A trim if you are afraid of change internals.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Resolved Holley terminator integration into CCRM
  • BrandonMP
  • Feb 25, 2026
SN95 4.6L Mustang Tech Aug 23, 2026
fasterthangas
F
