66stangbluework said:
im so worried I fried something *bangs head into wall repeatedly* If I have a new 4gauge wire running from the post on the 3g to the post on the solinoid do i still need the black/red wires
The black/orange wires should be left connected at the starter solenoid but not connected to the 3G alternator. That prevents any overload or fire problems when you use a properly fused 4 gauge power feed from the alternator to starter solenoid.
The secondary power ground is between the back of the
intake manifold and the driver's side firewall. It is often missing or
loose. It supplies ground for the alternator, A/C compressor
clutch and other electrical accessories such as the gauges.
Any car that has a 3G or high output current alternator needs
a 4 gauge ground wire running from the block to the chassis
ground where the battery pigtail ground connects. The best
place for the block ground is where the battery ground for the
starter bolts down. The 3G has a 130 amp capacity, so you
wire the power side with 4 gauge wire. It stands to reason that the
ground side handles just a much current, so it needs to be 4
gauge too.
The chassis ground and battery pigtail ground go to the bolt being
pointed at in the following photo.
Picture courtesy timewarped1972
Once you have fixed your ground problem, see "Help me create the Surging Idle Checklist" at
http://forums.stangnet.com/showthread.php?t=534062
for help with your idle problems. The first post contains all the updates to the fixes. I continue to update it as more people post fixes or ask questions.
