Surging Idle And Stalling
  • Thread starter Thread starter malice9005
  • Start date Start date May 19, 2013
malice9005
25
Moreno Valley, CA
May 19, 2013
  • May 19, 2013
Hey guys I my car is surging and stalling and theres a gas smell. I have changed the iac, egr, and tested the tps and have it set to .96 volts and still have the problem. I was just wondering if you guys could lead me in the right direction to get my car running right again.
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
May 19, 2013
  • May 19, 2013
You need to tell us more information about your setup- heads, cam. intake, etc. It could be anything from a dirty MAF to a vacuum leak to a bad FPR.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 19, 2013
  • May 19, 2013
You guys with idle problems could save a lot of time chasing your tails if you would go through the Surging Idle Checklist. Over 50 different people contributed information to it. The first two posts have all the fixes, and steps through the how to find and fix you idle problems without spending a lot of time and money. I continue to update it as more people post fixes or ask questions. You can post questions to that sticky and have your name and idle problem recognized. The guys with original problems and fixes get their posts added to the main fix. :
It's free, I don't get anything for the use of it except knowing I helped a fellow Mustang enthusiast with his car. At last check, it had more than 125,000 hits, which indicates it does help fix idle problems quickly and inexpensively.
malice9005
25
Moreno Valley, CA
May 20, 2013
  • May 20, 2013
Oh I've read the post and am very greatful for it but I did the fixes in it and didn't do much unfortunately but I will look over make sure I didn't miss anything. As for specs my car is all stock no mods and no maf.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 20, 2013
  • May 20, 2013
What year car, what transmission?
Is all the original emissions equipment in place and functional?
Did you get a code 11 when you dumped the codes? What other codes did you get?
Have you done cylinder balance test?
Have you done a full tuneup? That means new spark plugs, new spark plug wires, cap, rotor, fuel filter, air filter?
Are you using anything other than the stock airbox and the flat panel filter?
Have you checked and replaced all the vacuum lines? That includes the brake booster grommet and PCV grommet.
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
