  • 1994 - 1995 Specific Tech
Surging idle. Help!
  • Thread starter Thread starter Last5.0Cobra
  • Start date Start date Jul 10, 2009
Last5.0Cobra
15
Seattle, WA
Jul 10, 2009
  • Jul 10, 2009
Hello all. Thank you in advance for all of your help.
My car usually idles at 1000 rpm. Right now it is surging between 900-1100 consistently. Also any sudden stops, whether i push the clutch in or brake hard... it dies.
Anyway, i looked through a lot of old posts trying to figure out what the problem is. A few days ago i cleaned the iac, and it didn't seem to help. Maybe i need a new iac? One thing that i have noticed, is if i turn on or off the A/C the problem temporarily goes away.
I actually had a similar problem to this about a year and a half ago. That one turned out to be a bad MAF. This one is different though, because its not throwing any codes.
Some other advice that i already checked was... double checking the idle screw, I have a BBK 70 mm throttle body, so the idle screw is a little allen. (the other screw is frozen) I also tried resetting the codes (even though there was none.)
I know this could be a vacuum leak, but i am not sure where all the vacuum lines are, there aren't many.... right? Anyway, sorry for the long post, and thanks again guys.
hollywoodstang
1,095
Jul 11, 2009
  • Jul 11, 2009
I am having a same problem here. But mine is due to deleting the EGR and EGR tube...my car dies often and can't figure out why... I set the idle little higher 800-900 and it seems to be holding.
Did you delete your EGR as well? Without tune?
Peps will help out i hope
Thanks
L
Dizzy_ax
93
Troutdale Oregon
Jul 11, 2009
  • Jul 11, 2009
Same thing happend to mine, while coming to a stop it starts to die down then surge back up and holds, after 10-30 seconds (while at a stop light) it will almost die and come back again. I have had two tunes with my car so far and i think the tunner forgot to tune the EGR both times. And its a pain in the ass to even get back there to have him "tune" the egr out of the system.
Some day soon i hope to get back to him and have it "tuned out" i will post in here if it actually did anything because i have tried everything...
9
94cobra#519
86
fresno cali.
Jul 11, 2009
  • Jul 11, 2009
i have the same problem mainly when the engine is still cold. anyone have any ideas?
sublimobile
Indiana
Jul 13, 2009
  • Jul 13, 2009
Ladies and Gentlemen, Boys and Girls. Gather round, cus I think I know whats wrong with your car.
Let me run down my symptoms first, as I had the same issue.
-94 Mustang Cobra - 95K miles
-when coming to a stop, idle would drop too low and then surge back up too high.
-problem was more persistent when cold outside
-coming to quicker stops usually stalled out completely
-sometimes, just stopping at a stop sign would stall the engine
So my engine was leaking oil. Thought it was oil pan and this is a job if you dont know--have to jack up the engine, so I took it to the mechanic. He said it was leaking out the valve covers---wierd? He did a little investigating and found that my PCV valve was clogged. just full of c.rap.
Anyways, I wasnt expecting it, but by replaceing the clogged PCV valve, it fixed my idle surge/stalling issue. What a nice, easy surprise.
Try it out. Its cheap and its worked for me and one other guy I told already.
Good Luck
PS: I also did the IAC reaplcement and cleaned my MAF sensor before I found out the real culprit.
Last5.0Cobra
15
Seattle, WA
Jul 13, 2009
  • Jul 13, 2009
Okay, so no i haven't deleted my EGR literally or via tune.
Funny that you mention the PCV, because i thought that it might be the culprit and purchased one from a Ford dealership last week. When i got home i realized it wasn't where i thought it was..... where is the PCV valve located on our cars?
302GTS
If you need herpes, I'm your man!
Apr 20, 2009
481
Largo, FL
Jul 13, 2009
  • Jul 13, 2009
The PCV is in between a lower intake a hard place. It's behind the intake, I believe closer to the passenger side, but I could be wrong. I'm sure someone has a better idea, and I know I've seen a picture of where it's located, which I'll try and find tonight to post.
HISSIN50
34
129
Jul 13, 2009
  • Jul 13, 2009
Jeff is correct.
Replace the grommet and get a new screen (called a breather at parts stores) or clean your old one.
Use Motorcraft for the valve and grommet (aftermarket stuff doesn't fit tight enough all that often).
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
