suspension and brake problems.
  • Thread starter Thread starter nds03
  • Start date Start date Apr 15, 2005
N
nds03
166
  • Apr 15, 2005
i left my house the other day, i get down the street and my brake pedal went straight to the floor(no pressure). i took off my front wheel to find some fluid dripping off the spindle fluid seems to be coming out right where there it some rubber around the piston. i also found that one of the bolts or end caps(looks like a 1- 1 1/2 inch hex nut) on the upper control arm is missing on the side where it connects to the body. theres just a small bar going through a bigger hole in the control arm where the bushing or whatever should be there
1. where can i get a new brake caliper for the granada disk brakes and how much does it cost, or can i rebuild the one i have?
2. do i need a new control arm or can i buy whatever is supposed to be there and if i can, what is supposed to keep it from coming back off?
thanks, noah
geostang351
946
Danb., CT
Apr 15, 2005
  • Apr 15, 2005
Dude......what? You need to be a little clearer on your explaination/problem.
N
nds03
166
  • Apr 15, 2005
how do i post a picture?
thehueypilot
1,084
Medina,Tennessee
Apr 15, 2005
  • Apr 15, 2005
Sounds like you are leaking fluid out of the piston dust boot, which means you blew the piston seal. If the caliper bore is not scratched, pitted and rusted you could rebuild it. Any of the parts houses should carry rebuild kit or rebuilt calipers. You can also buy a rebuild kit for the upper control arm as well.
N
nds03
166
  • Apr 16, 2005
i can get a rebuilt caliper for 15 dollers so i think ille save myself the hassle and go with that. i guess ill get the rebuild kit for the con arm
thanks
R
ron67fb
1,117
SF Bay area, CA
Apr 17, 2005
  • Apr 17, 2005
If the hex is gone from your control arm, chances are the threads are too buggered up to accept a rebuild kit. The hole is probably elongated as well, and might be cracked. I'd just buy a pair of arms to be safe.
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
G
Auto City Classics 67-70 Mustang disc brake kit question/s
  • GOvert
  • Jun 30, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 30, 2026
GOvert
G
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
