  • SN95 4.6L Mustang Tech
Suspension help please
  • Thread starter Thread starter Seraphitia102
  • Start date Start date Jul 12, 2005
Seraphitia102
will post boobie pics for a supercharger
Oct 11, 2004
737
California
Jul 12, 2005
  • Jul 12, 2005
I went to Chicane Sport Tuning and Joe there recommended me get H&R springs, Bill Stein shocks/struts, caster/camber plates, and alignment, all for $1500. I don't have much to spend on suspension, but that's what Joe@Chicane recommends. I trust his judgement but I'm looking to spend a little less money. Do any of you guys know any good suspension setup that is cheaper? I hope to not use caster/camber plates if necessary. Any suggestions on something that has good ride quality and some sportiness to it?
AdRock
521
South Texas
Jul 12, 2005
  • Jul 12, 2005
If you want to go cheaper and still get a good ride then this is what I would suggest.
Ford C springs $140 http://www.mustangtuning.com/forac.html
Tokico Premium performance struts $326 a set (4 ) http://www.maximummotorsports.com/tokico.asp#PP
MM Caster Camber Plates $200 http://www.maximummotorsports.com/cc.asp
Control Arms http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7985335396&category=33583&rd=1 Granatelli makes decent stuff and these are on E-bay fairly frequently for $150 buy it now price.
So. You're looking at Roughly $750 for parts and then about $85 for an alignment
So, roughly $850 if you do the work yourself.
This is just stuff off of the top of my head so you might even be able to find this stuff cheaper if you do some searching and look for rebates.
Seraphitia102
Oct 11, 2004
737
California
Jul 13, 2005
  • Jul 13, 2005
how low do Ford C springs drop me by the way?
squares98
852
Orange,ca
Jul 13, 2005
  • Jul 13, 2005
with a Saleen Body Kit you may not want anthing much lower than 1.5 inches SO the Eibach Pro Kit, H&R Sports, and the Ford B or C, or Steeda Sport Springs will work, Pick your choice depending on how much stiffer you want you ride to be compared to stock.. I dont care what anyone says also but bilsteins are too stiff with regular <800 lb springs.
40th GT
916
Lawrenceville, GA
Jul 13, 2005
  • Jul 13, 2005
1.5" front and .75" the rear. Yeah, it'll give you a big rake so you might have to cut the rear springs a little.
If you're not planning to autocross, the Bullitt suspension would be a cheap alternative.
triggz
1,218
Gadsden, AL
Jul 13, 2005
  • Jul 13, 2005
Holy hell!
H&R springs = $200
struts/shocks = couple hundred maybe, any good heavy duty stuff for an 87-93 mustang (1" shorter for the lowering)
you wont need c/c plates, its a myth. all you need is 'camber bolts', my alignment guy gave them to me for free and otherwise theyre like 8 bucks.
did he want $600 to install that junk? christ almighty. suspension work is easy if your mechanically inclined and you really cant screw it up if you follow directions. he's trying to rape you.
Seraphitia102
Oct 11, 2004
737
California
Jul 13, 2005
  • Jul 13, 2005
well the Bilstein shocks and struts together are $629 (Maximum Motorsports). H&R Super Sports would be around $220, caster/camber plates would be $199, and labor is $245 for 3.5 hours of labor. $49 for alignment.
BooWFO
991
Louisville, KY
Jul 13, 2005
  • Jul 13, 2005
Do you have to have CC's maybe not but if you figure on that cost to begin with (I did even though now I don't need them) you'll be ahead of the game. Also if you shop around ie on the sale boards here, ebay, local boards you may be able to peice it together cheaper. If you can/will do the work yourself you can save some $$. But if you trust the shop and they are good save up and go there. BTW if you do it yourself, and don't do shocks/ struts at same time just unbolt the 2 bolts at the bottom of the strut is quicker easier and less chance of damaging yourself or car.
H
Hornetsnest
150
San Diego, CA
Jul 13, 2005
  • Jul 13, 2005
Bullitt Suspension $400 and MM Strut Tower Brace $135 on StangSuspension
FRPP Handling Kit $410 and FRPP Strut Tower Brace $110 on Summit
That's $520-535 for 4 Springs, 2 Shocks/2 Struts, 2 Sway Bars, and 1 Strut Tower Brace. It may not be a great road race suspension set-up, but for a good street ride it should be more than fine.
N
n0v8or
604
Rhode Island
Jul 13, 2005
#10
  • Jul 13, 2005
  • #10
What is your motivation for the suspension upgrades; appearance, handling, "cool factor", or all three? Which of these results will bring you the most satisfaction? Do you belong to a club whereby you can drive a car that has been similarly modified (it might not feel like you expect at all)?
If you just want to lower the car for looks, your body kit already makes it look lower than stock. Bigger tires would fill the wheelwells, further contributing to the appearance of a lower stance.
MT1083
1,033
Charlotte, NC
Jul 13, 2005
#11
  • Jul 13, 2005
  • #11
I bought Bilstein struts and shocks for around $469 on ebay a couple of months ago. Just do a search on Bilstein and you find a dealer named tec deals or something like that.
Strut Tower Help!
  • 93Nifty
  • Jan 10, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
General karthief
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
3K
Fox 5.0 Mustang Tech Apr 11, 2026
Fox Suspensión Noise
  • PonyGTrider
  • Nov 24, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 8, 2026
PonyGTrider
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
