I have HR race springs and Bils, and am about to start on the rest of the stuff. the following is what i am going to be getting, but looking for the most effective order to go in. each item will be done seperatly unless there will be a problem with doing it.
Steeda front sway bar /w bushings
steeda tie rod ends
mm adj rear sway bar
steeda steel LCAs
MM panhard bar
and at the end will be the Evo Tri link once everything else is done and adding HR super race in the rear.
I was thinking LCA, PHB, Front SB, tie rod ends, rear SB... but really dont know. the best order. Tom, your thoughts?
Torinalth
steeda tie rod ends
steeda steel LCAs
MM panhard bar
Torinalth
