  • SN95 4.6L Mustang Tech
Svt Cluster
  • Thread starter Thread starter m0squ1t0
  • Start date Start date Jul 18, 2012
M
m0squ1t0
103
  • Jul 18, 2012
So I've got a 03-04 Cobra gauge cluster coming in this week and I wanted to know if the speedometer will read correctly after I take it to the Ford dealer. I've tried doing google searoches and have found nothing. This is going into a 2001 GT.
txredgt
1,343
33
69
Jul 18, 2012
  • Jul 18, 2012
You will have issues with the PATS system, Speedometer, Odometer.
Without the pats system worked out first you will not be able to start the car. The other 2 issues you can drive the car with but these 2 items will be off.
M
m0squ1t0
103
  • Jul 19, 2012
The pats system is why im going to ford. Told the tech I had a new cluster coming in and if they could make it work with my pats and they said yes.. I would assume that once the car sees that the cluster is different it should calibrate ..
1fun281
438
Atlanta Georgia
Jul 20, 2012
  • Jul 20, 2012
If you have a handheld tuner, and you will need a dyno tuner to do it but im pretty sure you can turn off the pats system with a dyno tune it will work i believe
nyuk98gt
1,427
Chesterfield, MO
Jul 21, 2012
  • Jul 21, 2012
m0squ1t0
Having read a number of cluster swap threads, I am an internet expert (LOL). Actually, that's a bit of a disclaimer since my old car ('98) had a much different cluster than your car. But, here's some food for thought.
Swapping over the circuit board(s) is all that is required, isn't it? The PATS stuff is stored in the "brain" in the instrument cluster board. You should not need to have the PCM flashed for PATS for the SVT cluster swap.
Chris
M
m0squ1t0
103
  • Jul 22, 2012
Swapping the circuit board WILL NOT work. This is the cluster from the '03-'04 Cobra. This cluster lacks the "battery" gauge, and was replaced with a "boost" gauge. The PATS isn't the problem seeing as the dealer can flash the cluster to work (or I could disable the PATS via SCT ) the only issue I'm curious about is the calibration of the speedometer. (GT is a 150mph and SVT is 160mph) I know this isn't new territory so someone knows what needs to be done.
M
m0squ1t0
103
  • Jul 22, 2012
WMBurns, you seem to be a guru at all things mustang, any input?
M
m0squ1t0
103
  • Jul 22, 2012
http://www.stangnet.com/mustang-forums/threads/gauge-cluster-stuff.824493/#post-8301009
According to this thread the dealer can calibrate...I'll call them monday
txredgt
1,343
33
69
Jul 22, 2012
  • Jul 22, 2012
Lol my old thread! Yeah it can be done but I wasn't sure how it would mess with my tune from a sct tuner. I ended up at first using the back portion off my gt cluster and the cobra front with correcting the speedo and odometer being off with the tuner telling it I had bigger tires than I did.
After a while though I had them turn off the pats system in order to just use the complete cobra setup and swapped the backs again.
I believe I heard from the previous guy I got my cluster from you can have a locksmith program it too do that may be something to check on before going straight to the dealership.
M
m0squ1t0
103
#10
  • Jul 22, 2012
  • #10
You're saying that with the complete Cobra cluster, all you had to do was turn off the PATS (or in my case, make the cluster match the pats) and the cluster functioned properly? The speedo read correctly?
txredgt
1,343
33
69
Jul 22, 2012
#11
  • Jul 22, 2012
  • #11
I remember it was reading correctly or very close. I only had it this way a few months before I sold the car but I don't remember having any major issues with it. I never had it tested from the police or other source before I sold it so I can't say with 100% certainty.
D
Deleted member 38176
Jul 22, 2012
#12
  • Jul 22, 2012
  • #12
Wow what a royal pain in the ass. Is there any particular reason why you're so intent on having a Cobra cluster in your car? There are aftermarket GT gauge clusters that look almost identical to Cobra clusters......but without the ridiculous headache
3,287
24
69
Broke
Jul 22, 2012
#13
  • Jul 22, 2012
  • #13
Agreed.
M
m0squ1t0
103
#14
  • Jul 22, 2012
  • #14
This particular cluster is important because it was my brothers, it came out of his 03 SVT. The one that he was driving when he was hit by a drunk driver and killed. I'm building my car in his memory and the SVT cluster is a big part of that. I have his hood, his cluster, and his OEM wheels. This car will be a tribute clone. I'm not worried about whether or not it will be financially worth it or not, it goes beyond that.
Reactions: txredgt and Kilgore Trout
txredgt
1,343
33
69
Jul 22, 2012
#15
  • Jul 22, 2012
  • #15
Sorry to hear your loss man. It's a pretty cool tribute though that you are doing. If you need any other advice post up and the Stangnet clan are more than happy to help however we can!
M
m0squ1t0
103
#16
  • Jul 22, 2012
  • #16
Thanks man, it's overwhelming at times. As I said before I will be calling the dealer on monday and hoping for the best. Wanna get the cluster installed ASAP
D
Jul 22, 2012
#17
  • Jul 22, 2012
  • #17
Oh....wow....
RIP
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
P
Electrical 1988 GT Wrong Cluster- causing electrical issues?
  • pindude80
  • May 6, 2025
Fox 5.0 Mustang Tech May 6, 2025
pindude80
P
W
FoxBody Gauge Cluster - What would you pay?
  • wildstang17
  • Jun 25, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 26, 2025
Mustang5L5
F
1987 Mustang tachometer removal from cluster
  • FoxDude87
  • Mar 31, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 1, 2025
FoxDude87
F
