swapping in a C4
  • Thread starter Thread starter stangbuilder66
  • Start date Start date Apr 11, 2005
stangbuilder66
25
  • Apr 11, 2005
Hey guys, I did a search, maybe it was too quick, but didn't find what I was looking for. I currently have a 289 in a 302 block with a 3 speed bolted up. The car is a '66 that used to be a six cylinder way back before I ever had it. The guy that put in the 289 screwed up the z-bar for the clutch pedal and it is all screwy. I have recently been offered a C4 that was bolted to a 302 mustang, but was a later model for $50. I jumped at it, but don't have the tranny yet. My question is if I need to buy a new bellhousing or what I should look for. This is the tranny only, no bellhousing, flywheel, torque converter or block plate. What should I look for? I know I have to get a flywheel and torque converter, but don't know where to start. Anyone done this conversion before that might shed some light, or point me to a thread that might cover this subject.
Thanks.
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
There are active threads discussin this but basically you'll need to replace your flywheel with a flexplate, probably get the block plate and inspection plate while you are at it from the donor car. Possibly need a new crossmember too, but don't take my word for that. I've got a C4 crossmember that I'll sell you for dirt if you need one, it is from a 67 so I'm not sure if it will work or even be needed.
Don't forget the linkage for the shifter and the kick down.
stangbuilder66
25
  • Apr 11, 2005
Yeah, I already have the crossmember for a '66 C4, and I am restoring the car so I already have budgeted for a new carb (so I can get the kickdown there), and a new radiator (so I can get one for an auto). the main thing I am wondering is if I need to buy a new bellhousing, that is the only that that I am not for sure about.
Edbert
3,548
32
109
Austin TX
Apr 11, 2005
  • Apr 11, 2005
Nope, your 66 should bolt right up. Some very early small blocks used a different bolt pattern, but from late 65 on up through the 90s they were the same (THANK YOU FORD!).
84convertablegt
589
Columbus, OH
Apr 11, 2005
  • Apr 11, 2005
also, id forget about changing the radiator if its working ok. buy a external cooler for the tranny and mount in low in front of the current radiator. it will work much better and keep your tranny nice and cool. u will need the lines though that run from the tranny to the radiator, u will need the kick down, the shifter (id recommend hurst or other aftermarket) but if you stay stock style you will need the neutral safety swith and wiring for the back up lights and starter. the bellhousing should work just fine. oh yeah, u need a torque converter with a 10.5 bolt pattern and the matching flywheel. also, the converter has to match the tranny. c4's had two types, 24 spline for 60? till like 69 and after that they went to a 26 spline input shaft. You said its a later style c4 so its probably a 26 spline which is good because u have many more cheaper options for torque converters... thats why i bought a tci c4. that pretty much covers it. wait oh yeah, u need the metal vacuum line that runs from the intake to vacuum modulator on the tranny and possibly a tee if you have power brakes. DO NOT just run a rubber vacuum line, it will kink and mess up your tranny, it need to be almost all metal except for each end to connect it. now i think ive covered it all.
P
67 Mustang, with the 302 want to convert auto back to the original manual
  • Pdunn
  • May 3, 2026
Classic Mustang Specific Tech May 7, 2026
Mcmahst
Best place to source power steering parts for a '67? (control valve, ram, hoses)
  • SophiaTatum
  • Jun 15, 2026
Classic Mustang Specific Tech Jun 18, 2026
SophiaTatum
M
  • Poll Poll
Stroking a Mexico 289 or newer roller 302
  • MaryJaneTheMustang
  • Aug 12, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 12, 2026
Bullitt347
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
