Swaybar removal
  • Thread starter Thread starter gabe3586
  • Start date Start date Oct 14, 2006
gabe3586
40
  • Oct 14, 2006
Hey guys, I had a quick question. I always hear about people taking off there swaybar, what are the pros and cons of doing this? Will I lose handeling?
Thanks, Gabe
Jaswir
578
Orlando, FL
Oct 14, 2006
  • Oct 14, 2006
you will notice a difference... some people don't mind and some people put it right back on.... you get some bad understeer going around corners
cons .... more weight reduced from the front end... thats about it
9
9 Deuce GT
550
Geneva, NY
Oct 14, 2006
  • Oct 14, 2006
Yes you will lose handling. Why would you want to remove it? Is this car driven on the street? If yes, leave it on. It can be loosened at the track.
P
PJB
131
Rotterdam, NY
Oct 14, 2006
  • Oct 14, 2006
It will ride like a boat on water without it.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Oct 14, 2006
  • Oct 14, 2006
i took mine off. it sorta felt like a big crown vic around corners. more body roll in the front. but the car still handles good and i am not a corner carver so i wanted reduced weight. it had some weight.
now i cant even tell anymore.
88_GT_5_oh
Sportin' a turbo 5.0 in Canadistan
Jul 4, 2004
WPG/MB/CA
Oct 14, 2006
  • Oct 14, 2006
when one of my end links broke i noticed it right away... i would really liek to remove mine just for clearance with my turbo drain but i think i will leave it on cause it don't want to loose my street manners
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
T
Which to keep 1979 Ford Mustang or 2013 VW Jetta TDI Sedan
  • toasterboy1
  • Sep 13, 2025
  • Off-Topic Hangout
Off-Topic Hangout Sep 14, 2025
toasterboy1
T
