  • SN95 4.6L Mustang Tech
Switch chip
  • Thread starter Thread starter nhra427
  • Start date Start date Nov 19, 2004
nhra427
169
Oregon
Nov 19, 2004
  • Nov 19, 2004
I dont know much about the switch chips. I was wondering if anyone has heard of someone having 1 setup on the chip for gas mileage and the other setup for power. seems you could get some really good mileage if the puter was set for it.
CanadaStang
2,093
Mb
Nov 19, 2004
  • Nov 19, 2004
I have the 4 position chip, works great. I have several different tunes on it, and yes you can lean the a/f ratio out a bit, but I wouldn't lean it out very much as engines tend to cost more than fuel. My stock tune is about as lean as I want to go and I can flip it to that setting as I'm cruising down the highway.
nhra427
169
Oregon
Nov 19, 2004
  • Nov 19, 2004
where do you get those chips at?
Go HoTO!
602
Mountaintop, PA
Nov 20, 2004
  • Nov 20, 2004
Manny places, but www.modulardepot.com is an SCT dealer.
CanadaStang
2,093
Mb
Nov 20, 2004
  • Nov 20, 2004
Yup, thats where I got mine
Go HoTO!
602
Mountaintop, PA
Nov 20, 2004
  • Nov 20, 2004
I did have the SCT Programmer but traded it for a 4 Position Chip from SCT with another guy I met at MD. They are both at MD now getting the programs chaged.
I went with the chip as I got tired of changing the tunes with nitrous.
Question: Can you change the tunes on the fly? Or, do you need to restart the car?
T
turbokid
113
  • Nov 20, 2004
are you gusy talking about the delta chip by diablo??i saw a few on ebay that sold for around 200.
Go HoTO!
602
Mountaintop, PA
Nov 20, 2004
  • Nov 20, 2004
No. The we are ferring to the 4 position chip by SCT. It runs $325. I had that same Diablo chip and sent it back. The tune was screwed up and they could not get it right.
CanadaStang
2,093
Mb
Nov 20, 2004
  • Nov 20, 2004
The instructions that came with the 4 position chip says: The switch chips can be switched between the various settings 'on the fly' with the engine running.
I wasn't sure if that also ment the stock setting aswell, so I e-mailed MD with the question, within 10 min. they sent this reply:
>Glad to hear that it finally arrived. You are fine to switch it on the
> fly, even to stock. Enjoy!
> Danielle
Go HoTO!
602
Mountaintop, PA
Nov 20, 2004
#10
  • Nov 20, 2004
  • #10
> Danielle
That is awesome. You could not do that with the Diablo I had. You know if the car is tuned for gears, you be able to see the speedo change if you have gears while you are driving, right?
LS2 KLR
452
Houston, TX
Nov 21, 2004
#11
  • Nov 21, 2004
  • #11
I have a 3 position Diablo chip. I was told it was best to shut the car off and then switch it but I've tested it several times and it works fine switching on the fly.
CanadaStang
2,093
Mb
Nov 21, 2004
#12
  • Nov 21, 2004
  • #12
On your car yes, but not on mine as I would need a speedcal to recalibrate the speedo.The EEC does not have the capability to change the speedo on the older Stangs.
Go HoTO!
602
Mountaintop, PA
Nov 21, 2004
#13
  • Nov 21, 2004
  • #13
You can switch it, but the tune does not change unless you restart the car....at least that was how mine worked.
LS2 KLR
452
Houston, TX
Nov 21, 2004
#14
  • Nov 21, 2004
  • #14
My nitrous tune use to idle way low and usually caused my car to die if I didn't keep my foot on the pedal. I'd swap my tunes on the fly and I could always tell by my idle. I've updated my chip and have a much better tune and can't tell a difference now. I've sprayed it a couple of times on the fly and all has been well. However, I now shut off my car just in case, lol.
Electrical Defrost switch ignition?
  • Teen'93stang5.0
  • May 16, 2026
Fox 5.0 Mustang Tech Jun 3, 2026
Teen'93stang5.0
A
Electrical electric mirror switch issue...
  • alchemist1
  • Apr 18, 2026
Fox 5.0 Mustang Tech Apr 19, 2026
2000xp8
SJB Parasitic Draw, Fuse 59&67
  • 2005 Mustang V6
  • Apr 30, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 29, 2026
boatillo
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
A
Fuel Capable fuel system for +600hp
  • Avia.tuned
  • Feb 24, 2026
SN95 4.6L Mustang Tech Feb 24, 2026
squeak93
