Lets just hear what everyone would list as symptoms of a blown or leaking intake gasket. I've got some major gremlins that i can't seem to narrow down and i want other peoples opinions to make sure I'M on the right track.
Ok but what if it's out between cylinders and not around the edge of the intake? Or on the bottom side around the lifter valley?
Loss of coolant: can go directly into oil, or go into pistons and burn up.
Vaccume leaks causing idle issues.
Im not sure whats going on. I do know on the last set of felpros I installed that it was embossed in the gasket, right in the center HEAD SIDE.
I'll have to look at it but i think we have it ran off the coil and then to the relay and then to the fan...i'll have to double check but i'll look into that and see if it helps. I'm also going right now to have my alt tested just to make sure it's up to par.
By the way, where can i see pics of the '66? I always see it in your thread but i've never seen more of it![]()
