I have heard that a synthetic motor oil will assist in keep an engine cooler. True? If so, what type of oil works best? What are you guys using?
rbohm said:synthetic oils disapate heat better than mineral oils do, which is why they run cooler.
84convertablegt said:the only reason switching to synthetic could cause a leak is because the oil is slicker and finds a way to slip through gasket imperfections that dino oil would kind of clot up on
