T-5 Conversion issue
jxville
I could use some sound advice, as to my options.
I am converting a 1965 Mustang from automatic to the 5 speed T-5 transmission. In my infinite wisdom , the one I purchased is from a 1994. Knowing now that in the 94 and 95 the input shaft is longer. Here are my options as I see them. Spend the $200.00 and order the correct shaft or will a 94 bell housing bolt up and plan on cutting the floor another 2" back.
Any thoughts or other ideas would be greatly appreciated.
I'll second rbohm, get the 94 bellhousing. I put a 97 V6 (same torque rating as the earlier V8's) in my 66 coupe. It'll work to your advantage as the shifter ended up directly in the center of the factory hole (no cutting/trimming). Made my own mount. Not sure if the 94/5 T5's have an electronic speedo but double check. I had to convert and modify an earlier tailshaft housing and add a speedo gear. The output shaft still had the boss for the gear so that wasn't that big of a deal. If I were to do it again I'd probably swap to an elec. speedo instead. Is your engine original? If so, make sure to get the correct balance flywheel (28oz.). The clutch fork comes out lower in the bell which worked to my advantage with the Flowtech headers as it is lower than the tubes but still above the frame rails. I'm stuck on my conversion right now trying to figure out a hydraulic setup using over the counter parts instead of dropping $400 on the kits out there which won't work with the clutch fork on a 94 and later bell housing anyway.
+1 -- The 94-95 trans fits perfectly - no cutting of the shifter hole required. You'll have to fab something for the trans mount (I used the Fox trans mount for the '65 and modified it - pretty simple).
If you're willing to drop a few $, JMC has a ready-made kit for the 94+ trans that I've had working for past ~3 years. It works well and bolted right up. Call them directly - that's how I discovered that the piece even existed.
I put a 1996 World Class T-5 in m 65 back in 96. I used the California Pony Cars install kit with their stock type 65 shifter. It went in like a factory install. Clines cut the drive shaft for $35.00. Total outlay of less than $1500.00
