t-5 woes
  • Thread starter Thread starter TOOLOW91
  • Start date Start date Sep 22, 2011
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Sep 22, 2011
  • Sep 22, 2011
ok so i am on my way to work this morning car was fine the whole ride cruising in 5th at about 65 70 . i get off the exit on the high way slow down in neautral go to go into first and it feels real hard. so i get it into first and i stop again and i feel the shift has no side to side motion . so i muscle it around back and fourth real hard and it frees up. i get to work and im running through the gears in the parking lot and it binds again.
i removed the boot to see if maybe something was loose or debris were jamming up the shifter. nothing . any ideas ??
Mintsick
589
39
68
West Lafayette, IN
Sep 22, 2011
  • Sep 22, 2011
Does that Hurst shifter have the positive stops that are adjustable on it?
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Sep 22, 2011
  • Sep 22, 2011
yes it does it has a bolt and jam nut on both sides of it
Mintsick
589
39
68
West Lafayette, IN
Sep 22, 2011
  • Sep 22, 2011
I would check that the stops haven't backed themselves out somehow just because it's a simple thing to check, also check to make sure the 4 bolts holding the shifter onto the trans are snug.
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Sep 22, 2011
  • Sep 22, 2011
stops are tight , shifter isn't wobbling like it's loose , only does it if I put it into 5th and the. try to down shift but if I force it back in 5th and then neutral a second time
it frees u
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Sep 22, 2011
  • Sep 22, 2011
frees up* sorry I am on my iPhone
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Sep 22, 2011
  • Sep 22, 2011
so i checked the fluid and it seems to be full but i also had the car jacked up on the right side so i dont no im sure that didnt help, theres a small leak from whatever sensor is in the left side of the tranny .
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Sep 23, 2011
  • Sep 23, 2011
anyone ?
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Nov 5, 2011
  • Nov 5, 2011
bump stopped doing it for a while and started again today
V
vertvert
27
Nov 5, 2011
#10
  • Nov 5, 2011
  • #10
Sounds like a bent or binding fork. Or the shaft the fork rides on.
LarsD
2,680
119
123
Texas
Nov 5, 2011
#11
  • Nov 5, 2011
  • #11
How is your clutch cable adjustment?
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Nov 6, 2011
#12
  • Nov 6, 2011
  • #12
lars it feels like it catches real low to the floor like its supposed to, but then again its my first time with a 5 speed fox. it only behaves like this in 5th, every other gear is fine except sometimes reverse if i go to put it in reverse ill go from first down to reverse and normally it goes right in but sometimes it wont and if i let my foot of the clutch a little hair is goes right in.
LarsD
2,680
119
123
Texas
Nov 6, 2011
#13
  • Nov 6, 2011
  • #13
Hmm. Well it is supposed to have some pre-load to it. I found this out the hard way on my latest project. I check it by laying down next to the car and reaching under it to wiggle the clutch cable. Kinda hard to explain, but the cable should have a little bit of tension on it while at rest.
TOOLOW91
20+ Year Stangneter
8,762
234
S.I.NY
Nov 6, 2011
#14
  • Nov 6, 2011
  • #14
will do tonite or tomorrow. that may explain why when it wont go into reverse the little hair that i move the pedal is making up for the tension and allowing me to go into reverse
  • brandyn200
  • Jun 20, 2026
AeroCoupe
N
Power door lock motor Question
  • NYFox
  • Mar 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 17, 2026
NYFox
N
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
