T-5Z???
  • Thread starter Thread starter 2Tone5.0
  • Start date Start date Nov 19, 2007
2Tone5.0
63
Philadelphia
Nov 19, 2007
  • Nov 19, 2007
Can anyone tell me about this trans? I came across the name on a 93cobra website. Is it any good? Im going to need an upgraded trans for my car soon.
ninety15.0
1,336
  • Nov 19, 2007
If you are lookin at this trans for your DSS 331 blown car....i think you should look elsewhere for something tougher. The T-5Z is basically a 93 cobra T-5 with a longer 2.95 first and a slightly longer .63 5th. The input and output shaft diameters are the same. I think the gear cluster is hardened and it has a steel bearing retainer. but i believe the trans is still only rated a 330 350 ft-lbs. They claim a 450hp rating if you dont race it....so that means nothing.
I would look into an Astro or Gforce T-5...or you need to look at the TKOs. They are the only trans that will really hold up to some abuse behind a 450rwhp car.
2Tone5.0
63
Philadelphia
Nov 19, 2007
  • Nov 19, 2007
With the Astro and Gforce T-5 are they going to bolt up directly? or am i going to have to get different bellhousing, corssmember, etc...
ninety15.0
1,336
  • Nov 19, 2007
Both the astro and the G-force are in the stock t-5 case...they just feature larger diameter shafts and larger/more robust gears. You WILL need a different clutch as the stocker will not match up with the astro/g-force input shaft. But the crossmember and bellhousing should work as stock.
2Tone5.0
63
Philadelphia
Nov 21, 2007
  • Nov 21, 2007
I think Im going to do that. I was looking at both of them and you get a discount of giving them your old core. any of the two you recomend as in price and performace return, reliability, etc...?
L
lpgturbo
14
Austin,Tx.
Nov 22, 2007
  • Nov 22, 2007
I just built the A5 using Astro's gearset,the gears are very stout and will stand up to much more abuse than a stock T5 ever will. Be prepared to spend around $1100 just for the gearset alone. This is alot intially but in the long run a very good investment.My combo should be good for 550-600 RWHP,single turbo running 15 PSI of boost.
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Interior and Upholstery HVAC Mode selector vacuum switch issue.
  • parish99
  • Jul 3, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
KAWMAN2
User Profile
  • SammSwine
  • Jan 18, 2026
  • Feedback Area | Testing Zone
Feedback Area | Testing Zone Jan 18, 2026
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
