Idle - 1.256 WOT 5.22
Im pretty sure i did it right, these were the #'s i got is this good or bad?
MyCARneedsHelp said:Idle - 1.256 WOT 5.22
Im pretty sure i did it right, these were the #'s i got is this good or bad?![]()
MyCARneedsHelp said:i didnt get any memo
WOT should be just under 5 volts and koeo and koer should be the same.
Not doubting your word because you always have very useful info but not having the tps set w/i the correct perameter will turn on the CEL.jerry beach said:According to Charles Probst, it really doesnt matter what your TPS is set at if the car was made "since 1988". Whatever that means. I take it as 88 and newer. he says the computer takes the idle figure and uses it as a baseline whenever the key is turned on. I am giving this info off the top of my head, but its accurate. Get the book and read it.
