T-top conversion or not?
  • Thread starter Thread starter FALCONCRAFT
  • Start date Start date Mar 18, 2011
F
FALCONCRAFT
  • Mar 18, 2011
I am looking at an '88 GT ith a t-top. Is there a quick and easy way to tell if it is a factory t-top or a conversion?
I know they were made in the convertible line, but I don't find that info with the VIN.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Mar 18, 2011
  • Mar 18, 2011
Its not on the vin, it's on the door tag. If the door tag is missing, you are SOL
On the door tag, look for the item "S"
Black means a hard roof car
C means sunroof
D means t-roof
F
FoxChasis
20+ Year Stangneter
Dec 23, 2003
590
277
93
Apr 2, 2011
  • Apr 2, 2011
Besides the VC label (door tag), there is also a code on the body buck tag and the assembly line broadcast sheet.
The body buck tag is 3.5" x 1.5" metal tag stapled to the radiator support frame, behind the driver-side headlamp. That tag was used by the assembly line to build the basic body. Dearborn Assembly changed the tags for the '88 model year, and I'm only familiar with the arrangement on the '87 and earlier tags. On the earlier tags there is a "TR" code on the second line for a T-roof. Not sure about '88 tags.
The broadcast sheet (also called the "build" sheet) is an 11" x 8" paper sheet with a bunch of codes on it. They were taped all over the outside of the body to help the assembly line build the car. They were supposed to be discarded at the factory but you may find one or two under the carpet, or under the rear seat, or behind the interior quarter panels, or on top of the gas tank, etc. But you may not ever find one for the car. Again, I'm only familiar with the early sheets but on those sheets, on Line A, there is an "H" code in position 23 for a T-roof.
V
Paint and Body Problem with 1985 GT T-Top outside mirrors
  • Vatchy
  • Sep 9, 2025
Fox 5.0 Mustang Tech Sep 26, 2025
Vatchy
V
M
How To Decode
  • Malcoll1
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
FoxChasis
F
T
Newbie looking for some info on speedo gears
  • TDM389
  • Nov 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 16, 2025
TDM389
T
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
