94stroker said:Will a t45 out of a 94 gt fit in a 65 coupe????
All you need are the right swap parts, don't give up so easily, that extra gear will come in quite handy for mileage/driveability or rear-gear swaps.94stroker said:thats what i thought. i have one just laying around so i was going to see if i could use it. i guess ill just go with the 4 speed
. If your going with a cable clutch setup these trannys line up more toward the center of the factory shifter hole. the only time you have to change the input shaft is to retain the stock bell and then you have to use the adapter plate anyway.
