Drivetrain t5, help
  • Thread starter Thread starter afso
  • Start date Start date Sep 10, 2018
A
afso
48
texas
Sep 10, 2018
  • Sep 10, 2018
I have a 1990 5.0 5speed, will a 5speed out of a 98 mustang v6 fit and work
Dan02gt
mazing how much gas smell came from that tiny hole
20+ Year Stangneter
Mar 2, 2003
909
415
113
Greenville, NC
Sep 11, 2018
  • Sep 11, 2018
I think the input shaft is to long. You might be able to change that out though with a fox one. Also I think the torque rating on that trans it lower than the V8 T5. However I have heard that the T5s out of the 99-04 v6s were much stronger.
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 11, 2018
  • Sep 11, 2018
You need to swap the input shaft and bearing retainer, but only certain years are interchangeable IIRC, the 90-93 T5 gearset is the same as the 94+ T5 so they would work. You'll need to count teeth to be sure.
I also believe the T5 went to an electronic speedo in 1998, which is a bigger issue. Unsure if the mainshaft has the provision for a mechanical speedo drive gear, but then you'd need to swap the tailhousing.
Might be easier to just find a fox t5
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 11, 2018
  • Sep 11, 2018
Good thread that details out some of the steps needed to convert.
I'm not sure if 1998 was mechanical or electric speedo
https://forums.corral.net/forums/general-mustang-tech/1229754-2001-t-5-speedometer-gear-install.html
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Sep 11, 2018
  • Sep 11, 2018
different input shaft
Different gearing
Different output shaft and speedo gear
A
afso
48
texas
Sep 13, 2018
  • Sep 13, 2018
how bout a t5 out of a 94-95 v6
Mustang5L5
Mod Dude
Feb 18, 2001
43,392
18,135
224
Massachusetts
Sep 13, 2018
  • Sep 13, 2018
Swap input shaft and bearing retainer
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 14, 2018
  • Sep 14, 2018
A Tremec 3550/TKO/TKO 500/TKO 600 is a completely different transmission from a T5. Strong and almost bulletproof unless you run them without proper lubricant or full throttle shift without the clutch.
A Tremec T5 is still the same T5 that is prone to self destruction when used in a street/strip or racing environment
T5, all versions used in 5.0 Mustangs
Tremec 3550/TKO /TKO500/TKO600 AFTERMARKET replacement for T5 - handles racing environments with ease
See http://www.ttcautomotive.com/English/products/tremec.asp for more information - check out the "Light Duty" group, since TTC makes monster transmissions for big trucks as well as passenger cars.
T5 identifier information.
On the tail shaft of the transmission, there will be a stamped aluminum tag. The tag will have a number on it that you can cross reference to the chart below. There is no other way to find out what type of T5 it is without disassembling it. All the rest of the numbers on the outside of the T5 case are part numbers which are not unique to any particular T5 model.
Remember that 94 - 97 T5's have a longer input shaft (about 11/16” longer) and can only be used with a 94-95 bell housing unless you modify or replace the input shaft.
T5's used with a 4 cylinder have a 3.93 first gear, reduced torque ratings and an input shaft pilot diameter that is smaller that the T5 used for V6 & V8 engines. The pilot diameter is .59" compared to the .668" used on V6 & V8 T5's. It requires a different pilot bearing to be used with a V6 or V8. The pilot bearing you need is for a Ford Ranger diesel from AutoZone part #14672
I don't know how you feel about the DYI thing when it comes to gears, some people don't like the idea of working on transmissions. If the DYI transmission fix idea isn't something that you would rather leave to someone else, here are some resources:
See http://www.ttcautomotive.com/English/onlineorder/product.asp to download a FREE service manual for T5 or Tremec 3550/TKO
You will need the Adobe Acrobat viewer which is also a free download – http://get.adobe.com/reader/
See http://www.hanlonmotorsports.com/ or http://www.ddperformance.com for parts
A T5 rebuild kit with syncros, bearings and other small parts costs about $160. It does not include any gears or shafts.
http://www.hanlonmotorsports.com/ also has a video on how to rebuild your T5 or Tremec. It costs about $20, and is worth every penny of it.
I did a Tremec 3550 rebuild, and it wasn't that difficult. The video was an immense help, and I would recommend viewing it. At $20, it will give you an opportunity to look and decide for yourself if you think that it is something you want to try to do.
You'll need the shim kit below when you swap the input shaft.
T5 Shim kits – best product I have seen in a while… http://www.5speeds.com/t5/shims.html
“The Peel ‘n Place T5 World Class shim kit makes shimming T5 counter gear and main drive gears very easy.”
Grounding issue?
  • 86SilverFox
  • May 16, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 31, 2026
86SilverFox
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
9
For Sale Bundle of Muscle Mustangs and Fast Fords Magazines
  • '90LX351
  • Oct 22, 2026
  • Other Classifieds
Other Classifieds Oct 22, 2026
'90LX351
9
1990 foxbody 5.0 fuel system.
  • staceyj
  • Nov 28, 2025
Fox 5.0 Mustang Tech Nov 28, 2025
Mustang5L5
